1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <20132014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <20132014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: RE: National Instruments PCI DAQmx
From: "Gomella, Andrew (NIH/NHLBI) [F]" <[email protected]>
To: Rafael Vescovi <[email protected]>
Date: Tue, 28 May 2013 15:32:26 +0000
Hi Rafael,
I do not believe anyone is actively maintaining support for the Ni-DAQmx.
I also don't believe Henirch du Toit works on EPICS any more.
I think fixing up the COMEDI driver he wrote is probably the way to move forward (especially given its long list of supported hardware). I think if it is brought up to date with the changes that have been made to asyn it should work fine.
http://www.comedi.org/
http://sourceforge.net/projects/epicscomedi/
It does not compile for me with 3.14.12.1 and asyn-4-18, though it would have been a surprise if it did considering the time since its last update. I am trying to fix it up but I have no programming experience so it is fairly slow right now.
Andrew
Sent: Thursday, May 09, 2013 4:59 PM
To: [email protected]
Cc: [email protected]
Subject: National Instruments PCI DAQmx
Hello,
I would like to know if someone is still maintaining the support for NI-DAQmx?
If yes, are the PCI boards 6601 and 6602 compatible?
Rafael
Rafael Vescovi
State University of Campinas
Condensed Matter Physics Department
X-ray Applied Crystallography Laboratory
+55 19 35215497 tel
+55 19 35214146 fax
[email protected]
www.ifi.unicamp.br/~rvescovi
Re: National Instruments PCI DAQmx Andrew Johnson
National Instruments PCI DAQmx Rafael Vescovi
Prev: Re: Motor record .RDBD field Pearson, Matthew R.
Next: Re: Motor record .RDBD field Ron Sluiter
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <20132014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: National Instruments PCI DAQmx Rafael Vescovi
Next: Re: National Instruments PCI DAQmx Andrew Johnson
