Hi Andrew & Rafael,
On 2013-05-28 Gomella, Andrew (NIH/NHLBI) [F] wrote:
> I also don't believe Henirch du Toit works on EPICS any more.
Correct, he left iThemba LABS in 2008:
http://www.aps.anl.gov/epics/tech-talk/2008/msg00434.php
> I think fixing up the COMEDI driver he wrote is probably the way to move
> forward (especially given its long list of supported hardware). I think if
> it is brought up to date with the changes that have been made to asyn it
> should work fine. http://www.comedi.org/
> http://sourceforge.net/projects/epicscomedi/
It would probably be worth trying to get control of that epicscomedi project
at SourceForge if someone has the time to do that. I would suggest merging it
with the epics project http://sourceforge.net/apps/trac/epics/wiki but that's
up to whoever does the work (thank-you if you do).
I have been reading that some Comedi drivers are being reworked and added to
the Linux Kernel, although I have no idea whether this would affect the EPICS
drivers at all. Of course it'll be quite some time (years) before those make
it to the Red Hat releases (and hence to Scientific Linux) that many EPICS
labs actually use.
- Andrew
It is difficult to get a man to understand something, when his salary
depends upon his not understanding it. -- Upton Sinclair
- National Instruments PCI DAQmx Rafael Vescovi
- RE: National Instruments PCI DAQmx Gomella, Andrew (NIH/NHLBI) [F]
Re: EPICS on an embedded device Florian Feldbauer
Re: EPICS on an embedded device Diego Omitto
<2013>
2025
2026
EDM Zenon Szalata
<2013>
2025
2026
