1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <2013>  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <2013>  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: EPICS on an embedded device
To: "Vigder, Mark" <[email protected]>
Date: Tue, 28 May 2013 14:21:28 -0300
Hi Mark,
We are using Raspberry Pi and also a BeagleBoard but just for a few applications like temperature monitoring, simple serial devices and I/O control.
It seems to be a very reliable solution since they are running few months 24/7 without problems. Also it was very easy to compile and run them.
Diego Omitto
Computer Engineer
Beamline Software Group (SOL)
Brazilian Synchrotron Light Laboratory - LNLS/CNPEM
+ 55 (19) 3512-1228
[email protected]
www.lnls.br
2013/5/28 Vigder, Mark <[email protected]>
Greetings
I am looking at controlling some devices in my system using small SBC cards (e.g., PC104) and/or embedded small form factor PCs. I'm not very familiar with the products available and was hoping to get some advice on this forum as to what products people are using, what pitfalls are out  there, and general experiences with similar setups. I'm not looking at doing anything fancy, just run a soft IOC on a linux system to control one or two devices. I only need the standard I/O (serial, USB, network, perhaps some DIO). It doesn't need to be exceptionally rugged, though it will be running 24/7 in a fairly warm and dusty room, and may be unplugged and moved around regularly.
I want good software support. To me that means it comes pre-installed with a standard, supported linux distribution and I can cross-compile EPICS more or less out-of-the-box without having to resort to a lot of four-letter words.
We tried doing this on a Raspberry Pi - works great, certainly for prototyping. Cross-compiled and ran easily. But I'm not sure I want to use a RPi in production (or maybe it is good enough? Opinions?).
Any product info, experiences, thoughts, and opinions are greatly appreciated.
Thanks
Mark Vigder
Control System Architect
Canadian Neutron Beam Centre
EPICS on an embedded device Vigder, Mark
Prev: Re: National Instruments PCI DAQmx Andrew Johnson
Next: Re: Missing Windows Implementation of epicsLoadLibrary Andrew Johnson
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <2013>  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: EPICS on an embedded device Vigder, Mark
Next: Re: EPICS on an embedded device Jack
