1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <2013>  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <2013>  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: calcout OUT field to ASYN fails...
To: [email protected]
Date: Fri, 31 May 2013 15:08:19 +0200
Hi
I have the following records and the 'calcout' OUT field causes the IOC to fail
record(ao,"$(harp):range") {
     field(DTYP,  "asynInt32")
     field(OUT,   "@asyn(int32 $(mux))")
     field(FLNK,  "$(harp):checkrange")
record(ai,   "$(harp):trigger") {
          field(DTYP,  "Soft Channel")
          field(SCAN,  "Passive")
          field(FLNK,  "$(harp):checktrig")
record(fanout,   "$(harp):checktrig") {
          #field(SCAN,  "Passive")
          field(LNK1,  "$(harp):triggerOFF PP")
          field(LNK2,  "$(harp):triggerON PP")
          field(SELL,  "$(harp):trigger")
          field(SELM,  "Specified")
    record(calcout, "$(harp):triggerOFF") {
           field(SCAN,  "1 second")
          field(INPA,  "$(harp):trigger")
          field(INPB,  "$(harp):range")
          field(OOPT,  "On Change")
          field(DOPT,  "Use CALC")
          field(CALC,  "(A==0) && (B>10)?(B-10):B")
          field(OUT,   "$(harp):range PP")                   # THIS fails and stops the IOC
I can change the 'range' from any client though. It's only when I try it from within my db file.
Anyone know what I'm doing wrong ?
thanks
Amien
RE: calcout OUT field to ASYN fails... Mark Rivers
Prev: IP521 Feng Laurence
Next: EPICS Archive appliance Phillip Sorensen
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <2013>  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Next: RE: calcout OUT field to ASYN fails... Mark Rivers
