1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <2013>  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <2013>  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: RE: SEQ with dynamic assignment of PV in array variable
To: Al Honey <[email protected]>, "[email protected]" <[email protected]>
Date: Mon, 3 Jun 2013 12:38:37 -0700
My solution compiled, didn't segment fault, but also does not work !!!
Thank you Al for your suggestion.
I assume you are passing tel, sys, and d0/1/2/3 as parameters to your seq program.
In my case, I would like to use a static array (~parameters are hard-coded in program)
as I have 'too' many of them (~ 50 parameters)
Now I expect around 20 arrays, each with 50 assign statements
That's why I am looking at a for loop with pvAssign
So far pvAssign doesn't work on my side..
Anyone else?
To: [email protected]
Date: Mon, 3 Jun 2013 18:30:03 +0000
Hi Emmanuel
We do the following at Keck:
float openLoop[4];
assign openLoop[0] to "{tel}{sys}{d0}openLoop";
assign openLoop[1] to "{tel}{sys}{d1}openLoop";
assign openLoop[2] to "{tel}{sys}{d2}openLoop";
assign openLoop[3] to "{tel}{sys}{d3}openLoop";
monitor openLoop;
Al
From: [email protected] [mailto:[email protected]] On Behalf Of Emmanuel Mayssat
Sent: Monday, June 03, 2013 7:29 AM
Subject: SEQ with dynamic assignment of PV in array variable
Hello,
I am working on a seq program.
For that program, I am interacting with magnet power supplies.
The interfaces to the power supplies are all the same (about 10 PV each).
For each interface PV, I would like do to something like this...
#define NB_OF_SUPPLIES  50
short enable[NB_OF_SUPPLIES];
assign enable[0] to "I:S001:PS:EnableBO";
assign enable[1] to "I:SO10:PS:EnableBO";
monitor enable;
but programmatically.
I looked at the docs and they are somewhat confusing.
Q: Is there a place to put the pvAssign statement?
Q: Should the array's cell be initialized/assigned to ""  during declaration?
Q: Can I monitor a not-yet configured PV array?
Q: How can I find out about the connection to each of the PVs?
etc.
If anyone has an example of using pvAssign on array variables (i.e. enable),  I would appreciate it.
Emmanuel
RE: SEQ with dynamic assignment of PV in array variable Mark Rivers
SEQ with dynamic assignment of PV in array variable Emmanuel Mayssat
Prev: RE: SEQ with dynamic assignment of PV in array variable Emmanuel Mayssat
Next: Re: EPICS cross compile with buildroot problems Andrew Johnson
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <2013>  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Next: RE: SEQ with dynamic assignment of PV in array variable Mark Rivers
