Hi Emmanuel,
I am doing basically what you are doing in my SNL programs, and it is working fine. Here is an example with some unrelated lines removed.
/* Maximum number of detectors supported */
#define MAX_SIGNALS 32
int i;
int n;
int numSignals;
char temp[100];
char *prefix;
char *record;
char *field;
int ReadArray[MAX_SIGNALS];
assign ReadArray to
int ReadArrays; assign ReadArrays to "{P}DoReadAll";
monitor ReadArrays; evflag ReadArraysMon; sync ReadArrays ReadArraysMon;
int SNL_Connected; assign SNL_Connected to "{P}SNL_Connected";
int Acquiring; assign Acquiring to "{P}Acquiring";
ss mca_control {
state init {
when() {
prefix = macValueGet("P");
record = macValueGet("R");
field = macValueGet("FIELD");
numSignals = atoi(macValueGet("NUM_SIGNALS"));
if ((numSignals <= 0) || (numSignals > MAX_SIGNALS)) {
printf ("NUM_SIGNALS is illegal.\n");
numSignals = 0;
for (i=0; i<numSignals; i++) {
n = i+1;
sprintf(temp, "%s%s%d.%s", prefix, record, n, field);
pvAssign(ReadArray[i], temp);
} state waitConnected
state waitConnected {
when (pvAssignCount () == pvConnectCount ()) {
printf ("SIS: All channels connected.\n");
SNL_Connected = 1;
pvPut(SNL_Connected);
} state monitor_changes
Cheers,
From: [email protected] [[email protected]] on behalf of Emmanuel Mayssat [[email protected]]
Sent: Monday, June 03, 2013 2:38 PM
To: Al Honey; [email protected]
Subject: RE: SEQ with dynamic assignment of PV in array variable
My solution compiled, didn't segment fault, but also does not work !!!
Thank you Al for your suggestion.
I assume you are passing tel, sys, and d0/1/2/3 as parameters to your seq program.
In my case, I would like to use a static array (~parameters are hard-coded in program)
as I have 'too' many of them (~ 50 parameters)
Now I expect around 20 arrays, each with 50 assign statements
That's why I am looking at a for loop with pvAssign
So far pvAssign doesn't work on my side..
Anyone else?
To: [email protected]
Date: Mon, 3 Jun 2013 18:30:03 +0000
Hi Emmanuel
We do the following at Keck:
float openLoop[4];
assign openLoop[0] to "{tel}{sys}{d0}openLoop";
assign openLoop[1] to "{tel}{sys}{d1}openLoop";
assign openLoop[2] to "{tel}{sys}{d2}openLoop";
assign openLoop[3] to "{tel}{sys}{d3}openLoop";
monitor openLoop;
Al
From: [email protected] [mailto:[email protected]] On Behalf Of Emmanuel Mayssat
Sent: Monday, June 03, 2013 7:29 AM
Subject: SEQ with dynamic assignment of PV in array variable
Hello,
I am working on a seq program.
For that program, I am interacting with magnet power supplies.
The interfaces to the power supplies are all the same (about 10 PV each).
For each interface PV, I would like do to something like this...
#define NB_OF_SUPPLIES 50
short enable[NB_OF_SUPPLIES];
assign enable[0] to "I:S001:PS:EnableBO";
assign enable[1] to "I:SO10:PS:EnableBO";
monitor enable;
but programmatically.
I looked at the docs and they are somewhat confusing.
Q: Is there a place to put the pvAssign statement?
Q: Should the array's cell be initialized/assigned to "" during declaration?
Q: Can I monitor a not-yet configured PV array?
Q: How can I find out about the connection to each of the PVs?
etc.
If anyone has an example of using pvAssign on array variables (i.e. enable), I would appreciate it.
Emmanuel
- RE: SEQ with dynamic assignment of PV in array variable Emmanuel Mayssat
- Re: SEQ with dynamic assignment of PV in array variable Benjamin Franksen
- SEQ with dynamic assignment of PV in array variable Emmanuel Mayssat
Re: EPICS cross compile with buildroot problems Andrew Johnson
<2013>
2025
2026
<2013>
2025
2026
