Hi Emmanuel
I'm a bit late to the party but here goes:
On Monday, June 03, 2013 10:28:52 Emmanuel Mayssat wrote:
> I am working on a seq program.For that program, I am interacting with magnet
> power supplies.The interfaces to the power supplies are all the same (about
> 10 PV each). For each interface PV, I would like do to something like
> this...
> #define NB_OF_SUPPLIES 50short enable[NB_OF_SUPPLIES];assign enable[0] to
> "I:S001:PS:EnableBO";assign enable[1] to "I:SO10:PS:EnableBO";...monitor
> enable; but programmatically.
> I looked at the docs and they are somewhat confusing.
If in doubt, always refer to the SNL Reference ;-)
> Q: Is there a place to put the pvAssign statement?
pvAssign is not a statement, but a (built-in) function. See
http://www-csr.bessy.de/control/SoftDist/sequencer/Reference.html#pvassign
This means you can call it anywhere in action code. Typical places are: in a
global entry block, in an entry block of some initial state of some state set,
in a state transition from some initial state.
> Q: Should the array's cell
> be initialized/assigned to "" during declaration?
Yes, this is necessary because all (potentially) assign'ed variables must be
known statically. There are shorthands for this:
array int x[20];
double v;
assign v; /* same as assign v to "" */
assign x to {}; /* assign all elements to "" */
> Q: Can I monitor a
> not-yet configured PV array?
If you mean: before pvAssign was called (on some or all of the elements),
then: yes.
> Q: How can I find out about the connection to
> each of the PVs?
There are built-in functions pvConnected and pvAssigned, see
http://www-csr.bessy.de/control/SoftDist/sequencer/Reference.html#pvconnected
and
http://www-csr.bessy.de/control/SoftDist/sequencer/Reference.html#pvassigned
> etc. If anyone has an example of using pvAssign on array
> variables (i.e. enable), I would appreciate it.
If someone has a nice, self-contained example program to illustrate these
things, I will happily add it to the examples directory.
Cheers
Ben Franksen
() ascii ribbon campaign - against html e-mail
/\ www.asciiribbon.org - against proprietary attachm€nts
signature.asc
Description: This is a digitally signed message part.
- SEQ with dynamic assignment of PV in array variable Emmanuel Mayssat
RE: IP330 modules question Geon-Yeong Mun
Re: SEQ with dynamic assignment of PV in array variable Benjamin Franksen
<2013>
2025
2026
RE: SEQ with dynamic assignment of PV in array variable Mark Rivers
Questionable code in aToIPAddr Eric Norum
<2013>
2025
2026
