1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <2013>  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <2013>  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: RE: PV name change and autosave
To: Kevin Peterson <[email protected]>
Date: Fri, 7 Jun 2013 15:22:27 -0700
I am looking for a solution where just changing the PVname AUTOMATICALLY changes the autosave configuration.
in your case, if I understand correctly, changing a PVname ALSO requires a change in the req template or macros.
Obviously, compared to dbgrep or autosaveFields, the advantage of the req template for developers is that it is easy to identify what is being saved and what isn't. But to date, most of the problems I have with autosave is due to PV name changes and out-of-sync req file.
FYI
(Ok, another problem I have with autosave is its limitation to 8 req files)
E
> Date: Fri, 7 Jun 2013 16:34:24 -0500
> From: [email protected]
> To: [email protected]
> Subject: Re: PV name change and autosave
> CC: [email protected]
> The most common place for lines of that time is the auto_settings.req
> file. There is an example in the synApps xxx module:
> https://subversion.xray.aps.anl.gov/synApps/xxx/trunk/iocBoot/iocvxWorks/auto_settings.req
Re: PV name change and autosave Pete Jemian
PV name change and autosave Emmanuel Mayssat
Re: PV name change and autosave Tim Mooney
RE: PV name change and autosave Emmanuel Mayssat
Re: PV name change and autosave Kevin Peterson
Prev: Re: PV name change and autosave Tim Mooney
Next: et_wish installation nalaka samarasinghe
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <2013>  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: PV name change and autosave Kevin Peterson
Next: Re: PV name change and autosave Pete Jemian
