1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <2013>  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <2013>  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: PV name change and autosave
Date: Fri, 7 Jun 2013 10:30:40 -0700
To be compliant with a naming convention, changing the name of a PV should be a "trivial" operation.
That is true particularly for PV that are not used in higher level software (seq, feedback, info chart, etc)
Let's focus just for a moment on autosave.
Can the req file, generate itself "automatically"?
dbgrep *O > myfile.req
could do the trick, if you naming convention appends "O" at the end of the output records.
Unfortunately redirection on dbgrep doesn't work since 3.14.10...
Do redirection on dbgrep work in 3.14.12.3+ ?
Of course the req file can be generated manually starting with dbl * > dblist.raw
How do you generate you req file after a simple PV name change?
Emmanuel
Re: PV name change and autosave Kasemir, Kay
Re: PV name change and autosave Andrew Johnson
Re: PV name change and autosave Tim Mooney
Prev: new synApps module versions Tim Mooney
Next: Re: PV name change and autosave Kasemir, Kay
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <2013>  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
