On Jun 7, 2013, at 1:30 PM, Emmanuel Mayssat <[email protected]> wrote:
> Can the req file, generate itself "automatically"?
> dbgrep *O > myfile.req
One way is via annotations in the EPICS database:
record(type, "$(S):SomeRecord")
info(autosaveFields, "VAL LOW")
field(SCAN, "1 second")
field(INP, "whatever")
When you create new *.db files, it is easy enough to add those info annotations right away.
Assume, however, your application uses an existing *.db file. That *.db file contains the records that you need, but the original author did not include info annotations to support autosave:
# Original database that did not include info() statements
You may not want to edit these 3rd party *.db files because they originate from another distribution. When you later receive an update of those *.db files, you would have to re-apply your info annotations.
As a solution, note that you can load multiple definitions of the same record. You can load a second database file that contains the same record names, but only the missing infoannotations:
Anyway, finally you do this in the IOC startup file just before the usual create_monitor_set to create the config file from the record annotations:
makeAutosaveFileFromDbInfo("<IOCNAME>.req", "autosaveFields");
create_monitor_set("<IOCNAME>.req", 5)
-Kay
- PV name change and autosave Emmanuel Mayssat
Re: PV name change and autosave Andrew Johnson
<2013>
2025
2026
<2013>
2025
2026
