1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <2013>  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <2013>  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: LAN GPIB
To: Zenon Szalata <[email protected]>
Cc: [email protected]
Date: Thu, 13 Jun 2013 10:23:41 -0500
Just a side note. Back in 2010, our E5810A devices (firmware rev. A.01.09) failed a network scan. I contacted Agilent and they said they were aware of the issue and had no immediate plans to address it. The problem was that the vxWorks debugger was running in that firmware revision. Perhaps that was corrected in the E5810B version.
Tony
On Jun 13, 2013, at 10:10 AM, Zenon Szalata <[email protected]> wrote:
I am using both.  Both work reasonably well.  The Agilent unit is a bit more robust, since the ICS device is more likely to be adversely affected by computer security scans.  If you put the LAN-GPIB gateway on a private sub-net, then they both will do well.  The Agilent is significantly more pricey.
Zen
On 06/13/13 01:01, BOGARD Daniel wrote:
I plan to do GPIB with asyn using a LAN/GPIB  gateway and EPICS running on a Linux PC.
What is the best choice for the gateway between Agilent E5810B and ICS8065?
Thanks in advance.
Daniel Bogard
Accelerators Control engineer .
Saclay(France)
[email protected]
Anthony Pietryla
Controls Engineer
Advanced Photon Source
Argonne National Laboratory
Phone: 630-252-7430
Fax: 630-252-6123
LAN GPIB BOGARD Daniel
Re: LAN GPIB Zenon Szalata
Prev: Re: LAN GPIB Zenon Szalata
Next: Re: SEQ keep PV value during seq-init Benjamin Franksen
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <2013>  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Next: Why is RELEASE now included in CONFIG_INSTALLS ? Brian McAllister
