1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <2013>  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <2013>  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: SEQ keep PV value during seq-init
To: <[email protected]>
Date: Thu, 13 Jun 2013 17:53:59 +0200
On Wednesday, June 12, 2013 19:21:11 Fabian S. wrote:
> in my little sequencer program I defined
> double RUN;
> assign RUN to "{DEVICE}:ENA_CMD";
> monitor RUN;
> were "{DEVICE}:ENA_CMD"; is a bo record which is set to "1" and kept
> that way even if the iocapp restarts with autosave
> but during the iocstartup after the iocinit all is fine (bo still
> enabled ("1")) 'til the sequencer routine starts then it goes to
> disabled "0".
> Is there any chance to keep the PV values as it was during the seq-init?
I am not sure I understand. Are you claiming that in your setup the sequencer
somehow sets the value of the PV "{DEVICE}:ENA_CMD" to zero w/o anything in
the SNL program saying so? That would be a serious bug in the sequencer! Or do
you mean that in the program the variable RUN is zero, even though teh PV is
one. In teh latter case, could you make sure that the SNL program sees a
different value compared to what camonitor sees?
Cheers
Ben Franksen
()  ascii ribbon campaign - against html e-mail
/\  www.asciiribbon.org   - against proprietary attachm€nts
Attachment: signature.asc
Description: This is a digitally signed message part.
Re: SEQ keep PV value during seq-init [SOLVED] Fabian S.
SEQ keep PV value during seq-init Fabian S.
Prev: Re: LAN GPIB Anthony Pietryla
Next: Re: SEQ keep PV value during seq-init [SOLVED] Fabian S.
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <2013>  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: SEQ keep PV value during seq-init Fabian S.
