1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <20132014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <20132014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: VAL field of PV in ASYN driver
To: [email protected], Vikram Bhagat <[email protected]>
Date: Fri, 14 Jun 2013 10:43:29 -0500
Hi Vikram,
On 2013-06-14 Vikram Bhagat wrote:
> as i understand of i defiend VAL field to some value in DB file then it
>  sould be written on output.
> I have develop my own driver to write value on serial port using asyn
>  driver. and it is working fine.
> if i write some value . it is output on port.
> But if i write VAL field in DB file.   it is not writting that value to the
>  output
To write the record value to the port you have to arrange for the record to
be processed.  You can do this in several different ways, but depending on
your port driver not all of them will work.  The simplest is to set the PINI
field of the record to YES, which will cause it to be processed automatically
at IOC Initialization time.  However if your Asyn port has not connected up
to the device in time that might not work, and in that case a better solution
might be to put a command in your startup script to put the value at some
time after the call to iocInit, like this:
    iocInit()
    epicsThreadSleep(2)
    dbpf TEST:VAL 7
The epicsThreadSleep command might not be necessary in some cases, or you
might have to make the sleep delay longer according to how long it takes for
your particular Asyn port to connect.
- Andrew
It is difficult to get a man to understand something, when his salary
depends upon his not understanding it. -- Upton Sinclair
RE: VAL field of PV in ASYN driver Mark Rivers
VAL field of PV in ASYN driver Vikram Bhagat
Prev: Re: Support for TDK Lambda PS? Burkhard Kolb
Next: Device support for MKS PR4000 controller Sinclair, John William
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <20132014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: VAL field of PV in ASYN driver Vikram Bhagat
Next: RE: VAL field of PV in ASYN driver Mark Rivers
