1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <2013>  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <2013>  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Why is RELEASE now included in CONFIG_INSTALLS ?
To: [email protected]
Date: Fri, 14 Jun 2013 15:50:14 -0500
Hi Brian,
On 2013-06-13 Brian McAllister wrote:
> The last version I worked with was 3.14.8.2.  Sometime between that release
> and 3.14.12.3, the definition of "CONFIG_INSTALLS" in
> base/configure/CONFIG_COMMON was changed to include "RELEASE*".  I say
> "sometime" as this change is NOT DOCUMENTED in the release notes.
> Before I hack the config files to do what I want, I'd like to understand
> the purpose of this change.  There was a reason, right ?
The original purpose of INSTALL_LOCATION was to allow the built software tree
to be placed outside of the the source build tree, such as on a different
disk or in a common production area.  Some sites use this feature, although
many don't and we probably haven't tested it too carefully as the build
system has changed over the years.
For the resulting installed tree to be a standard top area that can be used
for building dependent modules against, it has to have a configure directory
with copies of the RELEASE* files from the source tree, since they get parsed
during the checkRelease process when building dependent modules.  I'm
guessing that back in November 2007 when this particular change was committed
someone had reported to Janet that you couldn't build dependent modules when
INSTALL_LOCATION was used because the RELEASE file was missing from the
installed tree.
You may also encounter the same problem with clashing RULES_BUILD files, if
you have two modules that both provide their own rules for gnumake.  The
sequencer is one such module, but there may not be any others so you could
get lucky there.
I've talked about this with Janet and we can't think up an easy solution at
this point, although we would like to be able to do this kind of installation
combining in the future; if you come up with any good ideas please let us
know.
- Andrew
It is difficult to get a man to understand something, when his salary
depends upon his not understanding it. -- Upton Sinclair
Why is RELEASE now included in CONFIG_INSTALLS ? Brian McAllister
Prev: Re: medm causes X11 crash on RHEL6 Faucett, John A
Next: RE: EPICS device disconnects and reconnects Feng, Kate
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <2013>  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Why is RELEASE now included in CONFIG_INSTALLS ? Brian McAllister
Next: calc DTYP Pearson, Matthew R.
