1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <20132014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <20132014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: analog output record - constant DOL
To: [email protected]
Date: Fri, 14 Jun 2013 17:51:51 -0500
Hi Rolf,
On 2013-06-14 you wrote:
> For DOL on output records, however, one could store the constant link
> value, which is evaluated on record init in a record private structure
> and pick it up from there when processing.
> Ideally this private value should be updated, if the value of the
> constant link is changed. Mhhh?
An output record could make the DOL field special(SPC_MOD) and redo the link
initialization whenever it gets set to a constant.  It would require adding a
new field to the record type to store the converted constant, and using that
value instead of the previous VAL when OMSL is closed_loop.  The attached
changes to the ao record type demonstrate this (but might not apply cleanly
using patch as they're against the latest 3.15 branch).
This is still a behavior change though, so I couldn't put it into an official
3.14 release.  I also don't think we can implement this solution everywhere;
ao, bo, dfanout, longout, mbbo and mbboDirect might arguably be done by
reasoning that they all have OMSL fields, but we're actually changing the
behavior of the DOL field more than OMSL, and in 3.15 the seq record has 16
of those.
I also just noticed that the ao's OIF == Incremental setting is ignored when
DOL is a constant; that's not really consistent either (or documented).
I don't think I want to make the change this way though, I'd rather take out
the special handling of const links from the record code as part of my link-
support changes, which should be more flexible and comprehensive.  It should
be possible to store the converted value in the link data structure and only
do the conversion when it gets changed, and I think the result will simplify
the record support code as well.
- Andrew
It is difficult to get a man to understand something, when his salary
depends upon his not understanding it. -- Upton Sinclair
=== modified file 'src/std/rec/aoRecord.c'
--- src/std/rec/aoRecord.c	2012-12-10 15:25:58 +0000
+++ src/std/rec/aoRecord.c	2013-06-14 19:26:38 +0000
@@ -120,8 +120,10 @@ static long init_record(aoRecord *prec,
     /* get the initial value if dol is a constant*/
     if (prec->dol.type == CONSTANT) {
-	if(recGblInitConstantLink(&prec->dol,DBF_DOUBLE,&prec->val))
-	    prec->udf = isnan(prec->val);
+        if (recGblInitConstantLink(&prec->dol, DBF_DOUBLE, &value)) {
+            prec->val = prec->docv = value;
+            prec->udf = isnan(value);
     /* must have write_ao function defined */
@@ -189,8 +191,10 @@ static long process(aoRecord *prec)
 	/* fetch value and convert*/
 	if (prec->pact == FALSE) {
-                if ((prec->dol.type != CONSTANT)
-                && (prec->omsl == menuOmslclosed_loop)) {
+            if (prec->omsl == menuOmslclosed_loop) {
+                if (prec->dol.type == CONSTANT)
+                    value = prec->docv;
+                else
                     status = fetch_value(prec, &value);
                 else {
@@ -270,6 +274,12 @@ static long special(DBADDR *paddr, int a
 	    return (status);
 	return (0);
+    case SPC_MOD:
+        /* DOL changed */
+        if (after && prec->dol.type == CONSTANT) {
+            recGblInitConstantLink(&prec->dol, DBF_DOUBLE, &prec->docv);
+        return 0;
     default:
         recGblDbaddrError(S_db_badChoice,paddr,"ao: special");
         return(S_db_badChoice);
=== modified file 'src/std/rec/aoRecord.dbd'
--- src/std/rec/aoRecord.dbd	2002-07-12 21:35:43 +0000
+++ src/std/rec/aoRecord.dbd	2013-06-14 19:49:21 +0000
@@ -35,6 +35,7 @@ recordtype(ao) {
 	field(DOL,DBF_INLINK) {
 		prompt("Desired Output Loc")
 		promptgroup(GUI_OUTPUT)
+		special(SPC_MOD)
 		interest(1)
 	field(OMSL,DBF_MENU) {
@@ -205,6 +206,11 @@ recordtype(ao) {
 		prompt("Current Raw Value")
 		pp(TRUE)
+	field(DOCV,DBF_DOUBLE) {
+		prompt("Desired Output Const")
+		interest(3)
+		special(SPC_NOMOD)
 	field(ORAW,DBF_LONG) {
 		prompt("Previous Raw Value")
 		special(SPC_NOMOD)
Re: analog output record - constant DOL Benjamin Franksen
Re: analog output record - constant DOL Rolf Keitel
Prev: RE: asynDriver R4-21: a possible patch for asynRecord.c: test on GigE camera Mark Rivers
Next: Re: EPICS device disconnects and reconnects Bruce Hill
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <20132014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: analog output record - constant DOL Rolf Keitel
Next: Re: analog output record - constant DOL Benjamin Franksen
