Am Samstag, 15. Juni 2013, 00:51:51 schrieb Andrew Johnson:
> I don't think I want to make the change this way though, I'd rather take
> out the special handling of const links from the record code as part of my
> link- support changes, which should be more flexible and comprehensive.
> It should be possible to store the converted value in the link data
> structure and only do the conversion when it gets changed, and I think the
> result will simplify the record support code as well.
I agree, and appreciate your efforts to improve link handling in 3.15. I have
often wished link handling were more orthogonal. In one of my self-written
record types I once had code that called recGblInitConstantLink at runtime
(each time the record was processed) because that really simplified the code
(I could save a number of record fields to store the constant value and could
avoid case distinctions). However, in practice it was too slow, so I had to
revert back to the standard method of using recGblInitConstantLink only in
init_record.
Cheers
Ben Franksen
() ascii ribbon campaign - against html e-mail
/\ www.asciiribbon.org - against proprietary attachm€nts
Aufsichtsrat: Vorsitzender Prof. Dr. Dr. h.c. mult. Joachim Treusch, stv. Vorsitzende Dr. Beatrix Vierkorn-Rudolph
Geschäftsführung: Prof. Dr. Anke Rita Kaysser-Pyzalla, Thomas Frederking
Postadresse:
Hahn-Meitner-Platz 1
D-14109 Berlin
- Re: analog output record - constant DOL Rolf Keitel
- Re: analog output record - constant DOL Andrew Johnson
RE: EPICS device disconnects and reconnects Mark Rivers
Error message control in StreamDevice Mark Rivers
<2013>
2025
2026
VAL field of PV in ASYN driver Vikram Bhagat
<2013>
2025
2026
