1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <20132014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <20132014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: RE: EPICS device disconnects and reconnects
To: "J. Lewis Muir" <[email protected]>
Cc: EPICS Tech-Talk <[email protected]>
Date: Tue, 18 Jun 2013 20:16:39 +0000
Hi Lewis,
>> What are the intended meanings of the other values of PINI and where is that documented?
>Hi, Mark.
>The one place I know of is in the release notes:
>  http://www.aps.anl.gov/epics/base/R3-14/12-docs/RELEASE_NOTES.html
> Search for "initHookAtIocRun".
Thanks, I knew I had seen it somewhere.  The Application Developer's Guide needs to be updated.
It seems to me that records with YES, RUN, and RUNNING would process (i.e. send values to the device) on reconnect events under my proposal #3.
Records with PAUSE, PAUSED could indicate records that should process on disconnect events?
But this is really overloading the meanings of these values and the PINI field, and a new record field or fields would be better.
Re: EPICS device disconnects and reconnects Kate Feng
EPICS device disconnects and reconnects Mark Rivers
RE: EPICS device disconnects and reconnects Mark Rivers
Re: EPICS device disconnects and reconnects Jason Abernathy
Re: EPICS device disconnects and reconnects Pearson, Matthew R.
Re: EPICS device disconnects and reconnects Ralph Lange
Re: EPICS device disconnects and reconnects J. Lewis Muir
Prev: Re: EPICS device disconnects and reconnects J. Lewis Muir
Next: RE: EPICS device disconnects and reconnects Mark Rivers
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <20132014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Next: Re: EPICS device disconnects and reconnects Kate Feng
