Hi Mark,
Would it be easier to use a file name to specify the records that
needed to be reset/restore
at reconnection, instead of using 'PINI' ? The filename could be
specified via prosilicaConfig().
For example:
prosilicaConfig(("$(PORT)", 192.168.0.20, 50,
0,"prosilicaConn.rec","P=13PS1:,R=cam1:")
The advantage is that the file could be modified even after IOC is
initialized.
The file would be similar to the format of auto_settings.sav file, but
one could specify the mode of
reconnection at the beginning of the file. The option of mode could be:
: 0) the specified default value,
1) the value from save/restore, if available, otherwise take the
default, 2) read from current camera
setting.
For example: prosilicaConn.rec
Mode 0
$(P):$(R):Gain 0
$(P):$(R):Acquire 0
$(P):$(R):FrameType 0
$(P):$(R):ImageMode 2
$(P):$(R):TriggerMode 0
Just some thoughts.
Cheers,
Kate
On 06/18/2013 04:16 PM, Mark Rivers wrote:
Hi Lewis,
What are the intended meanings of the other values of PINI and where is that documented?
Hi, Mark.
The one place I know of is in the release notes:
http://www.aps.anl.gov/epics/base/R3-14/12-docs/RELEASE_NOTES.html
Search for "initHookAtIocRun".
Thanks, I knew I had seen it somewhere. The Application Developer's Guide needs to be updated.
It seems to me that records with YES, RUN, and RUNNING would process (i.e. send values to the device) on reconnect events under my proposal #3.
Records with PAUSE, PAUSED could indicate records that should process on disconnect events?
But this is really overloading the meanings of these values and the PINI field, and a new record field or fields would be better.
- Re: EPICS device disconnects and reconnects Ralph Lange
- EPICS device disconnects and reconnects Mark Rivers
- Re: EPICS device disconnects and reconnects Kate Feng
- RE: EPICS device disconnects and reconnects Mark Rivers
- Re: EPICS device disconnects and reconnects Jason Abernathy
- Re: EPICS device disconnects and reconnects Pearson, Matthew R.
- Re: EPICS device disconnects and reconnects J. Lewis Muir
Re: AutoSAVE file cannot use substitution macros Amien TLABS
<2013>
2025
2026
<2013>
2025
2026
ANJ, 20 Apr 2015 |
Home
News
About
Talk
Base
Modules
Extensions
Distributions
Download
Documents
Links
Licensing
