1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <20132014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <20132014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: EPICS device disconnects and reconnects
To: EPICS Tech-Talk <[email protected]>
Date: Thu, 20 Jun 2013 16:21:39 +0200
Hm...
Yet another configuration file?
To me this sounds more like a case for info tags in the database.
~Ralph
On 20.06.2013 16:15, Kate Feng wrote:
> Hi Mark,
>     Would it be easier to use a file name to specify the records that
> needed to be reset/restore
> at reconnection, instead of using 'PINI' ?  The filename could be
> specified via prosilicaConfig().
> For example:
> prosilicaConfig(("$(PORT)", 192.168.0.20, 50,
> 0,"prosilicaConn.rec","P=13PS1:,R=cam1:")
>     The advantage is that the file could be modified even after IOC is
> initialized.
> The file would be similar to the format of auto_settings.sav file, but
> one could specify the mode of
> reconnection at the beginning of the file. The option of mode could
> be: : 0) the specified default value,
> 1) the value from save/restore, if available, otherwise take the
> default, 2) read from current camera
> setting.
> For example: prosilicaConn.rec
> Mode 0
> $(P):$(R):Gain 0
> $(P):$(R):Acquire 0
> $(P):$(R):FrameType 0
> $(P):$(R):ImageMode 2
> $(P):$(R):TriggerMode 0
>      Just some thoughts.
>     Cheers,
>     Kate
> On 06/18/2013 04:16 PM, Mark Rivers wrote:
>> Hi Lewis,
>>>> What are the intended meanings of the other values of PINI and
>>>> where is that documented?
>>> Hi, Mark.
>>> The one place I know of is in the release notes:
>>>   http://www.aps.anl.gov/epics/base/R3-14/12-docs/RELEASE_NOTES.html
>>> Search for "initHookAtIocRun".
>> Thanks, I knew I had seen it somewhere.  The Application Developer's
>> Guide needs to be updated.
>> It seems to me that records with YES, RUN, and RUNNING would process
>> (i.e. send values to the device) on reconnect events under my
>> proposal #3.
>> Records with PAUSE, PAUSED could indicate records that should process
>> on disconnect events?
>> But this is really overloading the meanings of these values and the
>> PINI field, and a new record field or fields would be better.
>> Mark
EPICS device disconnects and reconnects Mark Rivers
Re: EPICS device disconnects and reconnects Kate Feng
RE: EPICS device disconnects and reconnects Mark Rivers
Re: EPICS device disconnects and reconnects Jason Abernathy
Re: EPICS device disconnects and reconnects Pearson, Matthew R.
Re: EPICS device disconnects and reconnects Ralph Lange
Re: EPICS device disconnects and reconnects J. Lewis Muir
Prev: Re: EPICS device disconnects and reconnects Kate Feng
Next: Re: AutoSAVE file cannot use substitution macros Tim Mooney
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <20132014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Next: RE: EPICS device disconnects and reconnects Mark Rivers
