1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <20132014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <20132014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: starting Archive Engines
To: EPICS Tech Talk <[email protected]>
Date: Thu, 20 Jun 2013 11:40:30 -0400
I should add that I configured the RDB as follows and without errors:
./ArchiveConfigTool -engine CANbusRDB -config /data/CANbus/CANbusindex.xml -import -replace_engine -host localhost -port 4913
James
On Thu, Jun 20, 2013 at 11:39 AM, James F Ross <[email protected]> wrote:
Hello all,
I've managed to start an RDB archive engine using an xml file from the old channel archiver setup at STAR.
However, I feel like I'm doing something wrong.  The engine runs on the command line and none of the channels are connected, though I can see it at localhost:4913/main.
Here is how I start it: ./ArchiveEngine -engine CANbusRDB -port 4913
The SNS site documentation has -rdb_url, -rdb_user, and -rdb_password listed as options that should be used, but none of those are listed when I do ArchiveEngine -help and they throw an error when I use them to run the engine. I think they are built in to the plugin_customization.ini file for org.csstudio.archiver.engine, but they may still be needed on the command line.
Another bit of information is that I can't see this engine or RDB when I do a "show engines" or "show databases" from the archive user on mysql.  Perhaps I'm missing something that makes it run on mysql.
Thanks
James
starting Archive Engines James F Ross
Prev: starting Archive Engines James F Ross
Next: Re: starting Archive Engines Kasemir, Kay
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <20132014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
