1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <2013>  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <2013>  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: starting Archive Engines
To: James F Ross <[email protected]>
Date: Thu, 20 Jun 2013 11:58:35 -0400
If you run
 ArchiveEngine
and
 ArchiveConfigTool
they use the RDB URL, user, password that's in their built-in plugin_customization.ini.
You best create a settings.ini with your RDB URL, user, password, then call both with
 ArchiveEngine -pluginCustomization /path/to/those/settings.ini -engine ...
 ArchiveConfigTool -pluginCustomization /path/to/those/settings.ini -engine ...
That way, you're sure they talk to the same RDB.
In MySQL, "show databases" should list "archive" as one.
"show engines" might show you what database engines your MySQL setup supports (InnoDB, MyISAM, …).
To dump the engine info from the RDB in MySQL, use
  SELECT * FROM smpl_eng;
Refer to the org.csstudio.archive.rdb/dbd/mysql_schema.txt that you used to create the tables for more.
Still, if you say "I can see it at localhost:4913/main.": Does it list the groups and channels that you wanted to configure?
But they're all disconnected?
-> Then you probably need to set the EPICS CA addr list in your settings.ini
org.csstudio.platform.libs.epics/addr_list=127.0.0.1
is the default, will only look on the local host.
-Kay
On Jun 20, 2013, at 11:39 AM, James F Ross <[email protected]> wrote:
> Hello all,
> I've managed to start an RDB archive engine using an xml file from the old channel archiver setup at STAR.
> However, I feel like I'm doing something wrong.  The engine runs on the command line and none of the channels are connected, though I can see it at localhost:4913/main.
> Here is how I start it: ./ArchiveEngine -engine CANbusRDB -port 4913
> The SNS site documentation has -rdb_url, -rdb_user, and -rdb_password listed as options that should be used, but none of those are listed when I do ArchiveEngine -help and they throw an error when I use them to run the engine. I think they are built in to the plugin_customization.ini file for org.csstudio.archiver.engine, but they may still be needed on the command line.
> Another bit of information is that I can't see this engine or RDB when I do a "show engines" or "show databases" from the archive user on mysql.  Perhaps I'm missing something that makes it run on mysql.
> Thanks
> James
Re: starting Archive Engines James F Ross
Prev: Re: starting Archive Engines James F Ross
Next: help setting up XY table control with EPICS StreamerClass Christian Pauly
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <2013>  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Next: Re: starting Archive Engines James F Ross
