1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <2013>  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <2013>  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: caget can't connect to soft ioc on host with multiple NICs
To: Brian McAllister <[email protected]>, Andrew Johnson <[email protected]>
Date: Thu, 27 Jun 2013 03:42:24 +0000
A few suggestions:
1. Try cainfo your_pv and see what it tells you;
2. Use the command like echo $EPICS_CA_XXX to verify your settings;
3. Disable one of the two NICs using command like "ifconfig down eth0" or
"ifconfig down eth1" and restart your IOC to see if one NIC works for you;
Yong
On 6/26/13 8:18 PM, "Brian McAllister" <[email protected]> wrote:
>>>> On 6/26/2013 at 17:20:27 CDT, Andrew Johnson wrote:
>  > Do you have EPICS_CA_ADDR_LIST and/or EPICS_CA_AUTO_ADDR_LIST set in
>  > the environment that's running caget?  If so, what are they set to?
>They were not set.  I vaguely recall having to use them for some special
>case in the past, but generally have not, including on dual-NIC systems.
>In that case, there was no IOC on the host, rather all were on one of the
>two networks.
>I have now tried
>	setenv EPICS_CA_AUTO_ADDR_LIST NO
>with either
>	setenv EPICS_CA_ADDR_LIST "172.18.0.255"
>or
>	setenv EPICS_CA_ADDR_LIST "18.229.255.255"
>and caget still just times out.  I made sure to kill caRepeater in case
>its
>environment matters.
>Also, can you explain what this socket is for ?
>epicsdev   10u  IPv4 136864      0t0    UDP
>asym.mit.edu:33586->172.18.0.255:ca-2
>For completeness, ifconfig:
>eth0      Link encap:Ethernet  HWaddr 00:0C:F1:A1:C9:44
>          inet addr:18.229.0.31  Bcast:18.229.255.255  Mask:255.255.0.0
>          UP BROADCAST RUNNING MULTICAST  MTU:1500  Metric:1
>eth1      Link encap:Ethernet  HWaddr 00:A0:C9:CC:F2:FC
>          inet addr:172.18.0.100  Bcast:172.18.0.255  Mask:255.255.255.0
>BTW, the documentation on these variables is rather lacking.  The
>AppDevGuide refers to the CA Ref Manual, which lists them without really
>explaining what they do or how to use them in any detail.
>There are more detailed descriptions of a few in base/config/CONFIG_ENV
>but
>why would someone look there, as that file is not intended to be modified
>The descriptions of the EPICS_CA_* variables there are also not much more
>enlightening than the manuals.
>- brian
Re: caget can't connect to soft ioc on host with multiple NICs Brian McAllister
Prev: Re: caget can't connect to soft ioc on host with multiple NICs Brian McAllister
Next: RE: Record Processing Mark Rivers
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <2013>  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Next: RE: caget can't connect to soft ioc on host with multiple NICs Mark Rivers
