1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <2013>  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <2013>  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: RE: caget can't connect to soft ioc on host with multiple NICs
To: Brian McAllister <[email protected]>, Andrew Johnson <[email protected]>
Date: Thu, 27 Jun 2013 07:18:58 +0000
My next guess is that there may be a firewall running on your system. Is iptables running?
That is a common cause of the symptoms you are seeing.
From: [email protected] [[email protected]] on behalf of Brian McAllister [[email protected]]
Sent: Wednesday, June 26, 2013 7:18 PM
To: Andrew Johnson
Cc: [email protected]
Subject: Re: caget can't connect to soft ioc on host with multiple NICs
>>> On 6/26/2013 at 17:20:27 CDT, Andrew Johnson wrote:
  > Do you have EPICS_CA_ADDR_LIST and/or EPICS_CA_AUTO_ADDR_LIST set in
  > the environment that's running caget?  If so, what are they set to?
They were not set.  I vaguely recall having to use them for some special
case in the past, but generally have not, including on dual-NIC systems.
In that case, there was no IOC on the host, rather all were on one of the
two networks.
I have now tried
        setenv EPICS_CA_AUTO_ADDR_LIST NO
with either
        setenv EPICS_CA_ADDR_LIST "172.18.0.255"
or
        setenv EPICS_CA_ADDR_LIST "18.229.255.255"
and caget still just times out.  I made sure to kill caRepeater in case its
environment matters.
Also, can you explain what this socket is for ?
epicsdev   10u  IPv4 136864      0t0    UDP asym.mit.edu:33586->172.18.0.255:ca-2
For completeness, ifconfig:
eth0      Link encap:Ethernet  HWaddr 00:0C:F1:A1:C9:44
          inet addr:18.229.0.31  Bcast:18.229.255.255  Mask:255.255.0.0
          UP BROADCAST RUNNING MULTICAST  MTU:1500  Metric:1
eth1      Link encap:Ethernet  HWaddr 00:A0:C9:CC:F2:FC
          inet addr:172.18.0.100  Bcast:172.18.0.255  Mask:255.255.255.0
BTW, the documentation on these variables is rather lacking.  The
AppDevGuide refers to the CA Ref Manual, which lists them without really
explaining what they do or how to use them in any detail.
There are more detailed descriptions of a few in base/config/CONFIG_ENV but
why would someone look there, as that file is not intended to be modified ?
The descriptions of the EPICS_CA_* variables there are also not much more
enlightening than the manuals.
- brian
Re: caget can't connect to soft ioc on host with multiple NICs Brian McAllister
Re: caget can't connect to soft ioc on host with multiple NICs Andrew Johnson
Prev: RE: Record Processing Mark Rivers
Next: ca_get and ca_put triggered by monitors? Dirk Zimoch
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <2013>  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: caget can't connect to soft ioc on host with multiple NICs Hu, Yong
Next: Re: caget can't connect to soft ioc on host with multiple NICs Brian McAllister
