1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <2013>  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <2013>  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: caget apparent timeout
To: [email protected]
Date: Thu, 27 Jun 2013 17:14:55 -0400
Hi Andrew,
EPICS 3.14.12.2
Ubuntu 12.04.2
Pete.
On 06/27/2013 01:13 PM, Andrew Johnson wrote:
Hi Peter,
On 2013-06-27 D Peter Siddons wrote:
Occasionally, I need to check or change a PV, for which I use the
caget and caput command-line utilities. The operation (put or get) is
executed immediately, but then the PC waits for several seconds before
the cursor is returned. Does anyone know what is causing this? It feels
like a network timeout, but all I have is a PC and an IOC with a
crossover cable between. Anyone know the fix?
What version of EPICS were your caget/caput programs built against, and what
is the Linux version they're running on?  We used to see delays like this at
process shutdown while the atexit() routines were being run, but they were
cleaned up quite a few releases ago.
- Andrew
D. Peter Siddons
Detector Development Group Leader
Bldg. 535B
Photon Sciences Directorate,
Brookhaven National Laboratory
Upton, NY 11973
email: [email protected]
Phone: (631) 344-2738
RE: caget apparent timeout Mark Rivers
caget apparent timeout D Peter Siddons
Re: caget apparent timeout Andrew Johnson
Prev: querying for sets of pvs in archived data pthomas
Next: RE: caget apparent timeout Mark Rivers
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <2013>  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: caget apparent timeout Andrew Johnson
