Hi Peter,
On 2013-06-27 D Peter Siddons wrote:
> Occasionally, I need to check or change a PV, for which I use the
> caget and caput command-line utilities. The operation (put or get) is
> executed immediately, but then the PC waits for several seconds before
> the cursor is returned. Does anyone know what is causing this? It feels
> like a network timeout, but all I have is a PC and an IOC with a
> crossover cable between. Anyone know the fix?
What version of EPICS were your caget/caput programs built against, and what
is the Linux version they're running on? We used to see delays like this at
process shutdown while the atexit() routines were being run, but they were
cleaned up quite a few releases ago.
- Andrew
Advertising may be described as the science of arresting the human
intelligence long enough to get money from it. -- Stephen Leacock
- Re: caget apparent timeout D Peter Siddons
- caget apparent timeout D Peter Siddons
Re: caget can't connect to soft ioc on host with multiple NICs Andrew Johnson
querying for sets of pvs in archived data pthomas
<2013>
2025
2026
<2013>
2025
2026
