1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <2013>  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <2013>  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: caget can't connect to soft ioc on host with multiple NICs
To: "Brian McAllister" <[email protected]>, "[email protected]" <[email protected]>
Date: Thu, 27 Jun 2013 11:49:36 -0500
Hi Brian,
On 2013-06-27 Brian McAllister wrote:
> I still don't understand why it didn't work from the local host.  iptables
> accepts all traffic from the loopback.  Why doesn't that work for CA ?
It would have if you had added the loop-back address to EPICS_CA_ADDR_LIST;
by default CA deliberately excludes that from the list of interfaces it sends
searches to.  That exclusion makes perfect sense for VxWorks IOCs since there
is an internal short-cut between the client library and the RSRV for local
channels so there is no point sending search requests to yourself, that would
just be wasting CPU time.
For workstations where the CA server is in a different process sending
searches to the sub-net's broadcast address will still result in local
servers seeing the searches, so loop-back is not needed there either.  Maybe
CA should include the loop-back address if there are no other interfaces
available, but that wouldn't have helped your case anyway because there was
one, it was just fire-walled off.
You can find out more about the CA protocol in these slides:
    http://www.aps.anl.gov/epics/docs/AES2013/11-Protocol.pdf
- Andrew
Advertising may be described as the science of arresting the human
intelligence long enough to get money from it. -- Stephen Leacock
Re: caget can't connect to soft ioc on host with multiple NICs Brian McAllister
Prev: Re: Record Processing Zenon Szalata
Next: Re: caget apparent timeout Andrew Johnson
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <2013>  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: caget can't connect to soft ioc on host with multiple NICs Brian McAllister
Next: Re: caget can't connect to soft ioc on host with multiple NICs Dirk Zimoch
