1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <2013>  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <2013>  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: caget can't connect to soft ioc on host with multiple NICs
To: [email protected]
Date: Thu, 04 Jul 2013 09:44:43 +0200
On 27.06.2013 16:33, Brian McAllister wrote:
On 6/27/2013 at 7:18:58 -0000, Mark Rivers wrote:
   >  My next guess is that there may be a firewall running on your
   >  system. Is iptables running?
You are correct.  Inbound connections on eth1 were blocked and I had eth0
restricted to SSH/tcp while I was setting up the machine.  Normally I allow
all traffic from the local subnet.
Opening eth0 (or eth1) fixes the problem.  If I open both, then I need to
set EPICS_CA_AUTO_ADDR_LIST=NO and use EPICS_CA_ADDR_LIST.
I still don't understand why it didn't work from the local host.  iptables
accepts all traffic from the loopback.  Why doesn't that work for CA ?
- brian
BTW: We use iptables to block the second network port for CA instead of tweaking EPICS_CA_ADDR_LIST.
Dirk
Re: caget can't connect to soft ioc on host with multiple NICs Brian McAllister
Prev: RE: Please help us with some error when running a softGlue application! Mark Rivers
Next: Re: pvGet timeout in sequencer 2.1.12 Benjamin Franksen
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <2013>  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: caget can't connect to soft ioc on host with multiple NICs Andrew Johnson
Next: ca_get and ca_put triggered by monitors? Dirk Zimoch
