Hi Mark,
Yes it does. I believe it does get called for this record. I put a
print statement in the readInt32 routine and was surprised that it is
getting called for most of the implemented records, both longin and
longout. I have implemented action in the readInt32 routine for some of
the longin records. For any other record I call
status=asynPortDriver::readInt32 and status is returned.
Zen
On 06/26/13 22:59, Mark Rivers wrote:
It does not make sense that it is writing 0.
Does your driver implement readInt32 and does it get called during iocInit for that record? If so what does it return as the status function return value?
Sent: Wednesday, June 26, 2013 12:01 AM
To: Mark Rivers; [email protected]
Subject: Record Processing
Hi Mark,
I have a simple longout record
record( longout, "$(P):LO:DEBUG-$(M):MFUNC"){
field( DESC, "Modbus Func:")
field( DTYP, "asynInt32")
field( OUT, "@asyn(DEBUG,0,1)LO_MFUNC")
field( VAL, "3")
field( PINI, "YES")
It is a part of an IOC which uses asynPortDriver class driver. I put a
print statement in writeInt32 function and at IOC initialization time it
prints that the value to write is 0.
Then at the end of st.cmd script I have put a
dbpf <record name>.PROC 1
for this record and this time the value to write is 3. Why is the
record writing 0 at IOC initialize time?
I am not sure if this is a basic EPICS or asyn issue, so I thought I ask
you.
Zen
- RE: Record Processing Mark Rivers
- Record Processing Zenon Szalata
Re: caget apparent timeout D Peter Siddons
Re: caget can't connect to soft ioc on host with multiple NICs Andrew Johnson
<2013>
2025
2026
<2013>
2025
2026
