1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <2013>  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <2013>  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: specifying network interface with pcaspy caServer
To: Tech Talk <[email protected]>
Date: Fri, 28 Jun 2013 10:26:52 -0700
Hi, folks.  I have a question about the caServer as provided by the
pcaspy python package.  I hope this is an appropriate place to ask.
I'm wondering how to specify the network that the caServer binds to.  If
I run the example/dummy.py server script that comes with the source, it
works fine if I have an active outward-facing network interface.
However, if I'm offline I get the following error:
servo:~/src/pcaspy/git 0$ python ./example/dummy.py
filename="../../../../src/cas/io/bsdSocket/casDGIntfIO.cc" line number=121
server isnt attached to a network - unable to continue
filename="../../../../src/cas/io/bsdSocket/caServerIO.cc" line number=131
Attempt to set server's IP address/port failed unable to attach any interface
filename="../../../../src/cas/generic/caServerI.cc" line number=62
server isnt attached to a network - CA server internals init unable to continue
terminate called after throwing an instance of 'int'
Aborted
Presumably it's trying to bind to an interface that doesn't exist or is
not configured.  I would like to specify that the server just bind to
the loopback interface.  Does anyone know accomplish this?
Any advice would be great appreciated.  Thanks!
jamie.
Attachment: pgpxAywbmm437.pgp
Description: PGP signature
Re: specifying network interface with pcaspy caServer Xiaoqiang Wang
Prev: RE: querying for sets of pvs in archived data pthomas
Next: Re: Problem in errlogRemoveListener Andrew Johnson
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <2013>  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: RE: Sub-arrays Dalesio, Leo
Next: Re: specifying network interface with pcaspy caServer Xiaoqiang Wang
