1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <2013>  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <2013>  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: specifying network interface with pcaspy caServer
To: Jameson Graef Rollins <[email protected]>
Cc: Tech Talk <[email protected]>
Date: Fri, 28 Jun 2013 22:35:48 +0200
Hi Jamie,
On my Mac OS with EPICS 3.14.12.3, the following command works,
$ EPICS_CAS_INTF_ADDR_LIST="localhost" python dummy.py
Best
Xiaoqiang
On Jun 28, 2013, at 7:26 PM, Jameson Graef Rollins <[email protected]> wrote:
> Hi, folks.  I have a question about the caServer as provided by the
> pcaspy python package.  I hope this is an appropriate place to ask.
> I'm wondering how to specify the network that the caServer binds to.  If
> I run the example/dummy.py server script that comes with the source, it
> works fine if I have an active outward-facing network interface.
> However, if I'm offline I get the following error:
> servo:~/src/pcaspy/git 0$ python ./example/dummy.py
> filename="../../../../src/cas/io/bsdSocket/casDGIntfIO.cc" line number=121
> server isnt attached to a network - unable to continue
> filename="../../../../src/cas/io/bsdSocket/caServerIO.cc" line number=131
> Attempt to set server's IP address/port failed unable to attach any interface
> filename="../../../../src/cas/generic/caServerI.cc" line number=62
> server isnt attached to a network - CA server internals init unable to continue
> terminate called after throwing an instance of 'int'
> Aborted
> Presumably it's trying to bind to an interface that doesn't exist or is
> not configured.  I would like to specify that the server just bind to
> the loopback interface.  Does anyone know accomplish this?
> Any advice would be great appreciated.  Thanks!
> jamie.
Re: specifying network interface with pcaspy caServer Jameson Graef Rollins
Prev: registerRecordDevice... crashes IOC during startup Benjamin Franksen
Next: Re: specifying network interface with pcaspy caServer Jameson Graef Rollins
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <2013>  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: specifying network interface with pcaspy caServer Jameson Graef Rollins
