1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <2013>  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <2013>  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Updating the RDB archiver at the STAR experiment
To: "Kasemir, Kay" <[email protected]>
Date: Mon, 1 Jul 2013 09:05:54 -0400
Hi Kay,
I changed the last 8 integers in the argument to double as the function requires a double array as an input. That fixed the problem. Is that okay to do? I guess so. Thanks for your input.
Sincerely, Chanaka.
On Jul 1, 2013, at 8:39 AM, Kasemir, Kay wrote:
> Hello:
> Yes, I have seen that problem, but only with some versions of the Java 7 JDK. Not since 1.7.0_21.
> The easiest thing you can do right now is simply comment that line in org.csstudio.archive.vtype/test/VTypeFormatTest.java  in your copy of the sources:
>   //    value = new ArchiveVNumberArray(now, AlarmSeverity.NONE, "", display, 72, 101, 108, 108, 111, 32, 33, 0);
> In the 3.2.x branch of the repository it is actually commented out like that.
> This is only a unit test. It's not part of the executable product.
> Thanks,
> Kay
> On Jun 29, 2013, at 3:43 PM, "L. C. De Silva" <[email protected]> wrote:
>> Hi all,
>> I am currently updating the RDB archiver for the STAR experiment using the most recent git-hub master branch plugins and ran into a slight problem. After importing the plugins using eclipse I am getting an error (red cross) in the org.csstudio.archive.vtype/test/VTypeFormatTest.java file. In that file, under the testFormats function, at line 66 I am getting the error:  The constructor ArchiveVNumberArray(Timestamp, AlarmSeverity, String, Display, double[]) is ambiguous. Has anybody run into this problem and could anyone help me resolve this problem.
>> Thanks, Chanaka.
>> L. C. De Silva
>> Postdoctoral Research Fellow
>> Department of Physics
>> Creighton University
>> Omaha, Nebraska
>> Phone: 313-820-9507
>> Email: [email protected]
L. C. De Silva
Omaha, Nebraska
Phone: 313-820-9507
Re: Updating the RDB archiver at the STAR experiment Kasemir, Kay
Updating the RDB archiver at the STAR experiment L. C. De Silva
Prev: Re: Updating the RDB archiver at the STAR experiment Kasemir, Kay
Next: Re: Updating the RDB archiver at the STAR experiment Kasemir, Kay
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <2013>  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
