1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <2013>  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <2013>  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Updating the RDB archiver at the STAR experiment
To: "Kasemir, Kay" <[email protected]>
Date: Mon, 1 Jul 2013 09:55:55 -0400
Alright Kay.
Thanks for the input. Chanaka.
On Jul 1, 2013, at 9:19 AM, Kasemir, Kay wrote:
> On Jul 1, 2013, at 9:05 AM, "L. C. De Silva" <[email protected]> wrote:
>> I changed the last 8 integers in the argument to double as the function requires a double array as an input. That fixed the problem. Is that okay to do? I guess so. Thanks for your input.
> There is one method that takes doubles, one that takes int, one that takes longs.
> The test is meant for testing the 'int' version. Some versions of the compiler seem to have trouble deciding on whether they should use the int, double or long version for that type of input.
> If you change all the values to double, it will obviously compile, but there is already a different test for double args.
> Since this is just a test, just comment it out and ignore.
> Thanks,
> Kay
L. C. De Silva
Postdoctoral Research Fellow
Department of Physics
Creighton University
Omaha, Nebraska
Phone: 313-820-9507
Email: [email protected]
Updating the RDB archiver at the STAR experiment L. C. De Silva
Re: Updating the RDB archiver at the STAR experiment Kasemir, Kay
Re: Updating the RDB archiver at the STAR experiment L. C. De Silva
Prev: Re: Updating the RDB archiver at the STAR experiment Kasemir, Kay
Next: Re: registerRecordDevice... crashes IOC during startup Ron Sluiter
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <2013>  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Next: Support for Amp Tek X-123 David Reid
