1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <20132014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <20132014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: RE: asyn+streamDevice hangs with synchronousLock:Yes
To: Brian McAllister <[email protected]>
Date: Thu, 4 Jul 2013 06:38:42 +0000
Hi Brian,
I didn't see a response to my previous 2 questions:
> When it is hung please do
> epicsMutexShowAll 1
> If you simplfy your problem to a single record does the problem go away?
From: [email protected] [[email protected]] on behalf of Brian McAllister [[email protected]]
Sent: Wednesday, July 03, 2013 3:36 PM
To: Mark Rivers
Cc: Dirk Zimoch; [email protected]
Subject: Re: asyn+streamDevice hangs with synchronousLock:Yes
>>> On 7/3/2013 at 17:37:42 -0000, Mark Rivers wrote:
  > Brian, can you please send your StreamDevice protocol file?
# stream protocol file for Omega HX86PA
getRH {
  in "%RH=%f,AT\0370C=%*f,psia=%*f";
getAT {
  in "%RH=%*f,AT\0370C=%f,psia=%*f";
getP {
  in "%RH=%*f,AT\0370C=%*f,psia=%f";
The device sends data in this format:
\n\r%RH=100.00,AT\0370C=22.66,psia=14.66
  > Also, are you using the standard asyn IP driver, or are you using some
  > other asyn port driver?
drvAsynIPPortConfigure("HX86PA","172.18.0.13:2000 TCP",0,0,1)
- brian
Re: asyn+streamDevice hangs with synchronousLock:Yes Brian McAllister
Prev: Please help us with some error when running a softGlue application! 周永年
Next: MsAceess Database and CSS connectivity Ganesh Jangir
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <20132014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: asyn+streamDevice hangs with synchronousLock:Yes Brian McAllister
Next: Re: asyn+streamDevice hangs with synchronousLock:Yes Brian McAllister
