1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <20132014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <20132014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: catching python exception in pcaspy
To: Jameson Graef Rollins <[email protected]>
Cc: Tech Talk <[email protected]>
Date: Sun, 7 Jul 2013 23:02:53 +0200
I have the same headache when debugging pcas applications.
The server tool library does not provides an exception handler, like in the CA client library, this error could only be checked from the console. Even though, the error seems ambiguous and can not be directly related to the python code.
So I normally separate functions into its own module/class/function and test them.
And then interface to it by subclassing pcaspy Driver.
Best
Xiaoqiang
On Jul 7, 2013, at 9:42 PM, Jameson Graef Rollins <[email protected]> wrote:
> Hi, folks.  I'm wondering if it's possible to catch python exceptions in
> the pcaspy Driver class.  For instance, I have a very simple dummy
> server (attached), in whose write() method there is a call that should
> throw a NameError.  However, when the server is running, a CA write
> (e.g. "caput MTEST:RAND 3") produces the following output:
> filename="../../../../src/cas/generic/st/casStreamOS.cc" line number=479
> Internal failure - unexpected problem with client's input - forcing disconnect
> The server process also continues to run.
> Is there a way to get a proper python exception out of this situation?
> I would prefer the server to terminate with the exception, but I would
> be ok with the server continuing to run if the exception in the Driver
> could at least be reported to stderr or the like.  As is it's a little
> tricky to debug these errors.
> Thanks in advance for any help.
> jamie.
> #!/usr/bin/env python
> From pcaspy import Driver, SimpleServer
> prefix = 'MTEST:'
> pvdb = {
>    'RAND' : {
>        'prec' : 3,
> class myDriver(Driver):
>    def  __init__(self):
>        super(myDriver, self).__init__()
>    def write(self, channel, value):
>        foo
> if __name__ == '__main__':
>    server = SimpleServer()
>    server.createPV(prefix, pvdb)
>    driver = myDriver()
>    while True:
>        server.process(0.1)
Re: catching python exception in pcaspy Jameson Graef Rollins
Prev: catching python exception in pcaspy Jameson Graef Rollins
Next: RE: asyn+streamDevice hangs with synchronousLock:Yes Mark Rivers
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <20132014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Next: Re: catching python exception in pcaspy Jameson Graef Rollins
