1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <2013>  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <2013>  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: registerRecordDevice... crashes IOC during startup
To: Ron Sluiter <[email protected]>
Date: Tue, 9 Jul 2013 17:24:59 -0700
Sorry for the late reply, I was out last week.
I haven't had occasion to use EPICS with vxWorks, but
I have encountered and resolved these problems of
undefined symbols and c++ initializers with vxWorks
in a prior life.
We were using vxWorks 5.4, and to make undefined
symbols break at build time instead of run time, our first
solution was to do an additional static link with the vxWorks
image during the build, even though we still loaded
the relocatable app into a booted vxWorks.
This worked, but required some customizing of the vxWorks
build system to create a relocatable object which matched the
boot image.   You need to do a partial link to pull the libs you'll
need from the vxWorks libraries, but still generate a relocatable
object file.
An easier approach from the vxWorks build system
perspective is to create a target that links your relocatable object
into a bootable vxWorks image.   That approach probably wouldn't
work well for EPICS as you'd have to run the vxWorks build after
the EPICS build and find some way to point the vxWorks build at
your relocatable EPICS object file.    When I did this, we had a single
app with no loadable modules.
Both approaches worked, albeit at different companies, and in both cases
we eventually started booting a single bootable image with vxWorks
and our app as it shaved some time off the bootup.
However, actually running that bootable image containing both vxWorks
and our application which included c++ static initializers, required
some changes both to our c++ code and vxworks.   The main problem was
that the c++ static initializers run much earlier with this approach.
As I recall, we had to change to deferred initialization for c++ classes
that relied on some of the vxWorks services that were not available at
the time the initializers were being called.   I think we also customized
the vxworks usrKernel.c file so the initializers would be called later after
more of the os was up.
Hope this helps.
- Bruce
On 07/01/2013 07:44 AM, Ron Sluiter wrote:
On 6/29/2013 12:09 PM, Andrew Johnson wrote:
That seems like it might be half-way to us creating a fully bootable image file containing both the IOC application code and the VxWorks OS, but I don't think that would be quite as easy as it might seem because getting initialization right (C++ static initializers for our code) could be tricky. Has anyone ever tried to do that?
I sent a a message to tech-talk on this topic last month and got no replies.
I have created a bootable image that contains both the VxWorks OS and an EPICS IOC using Wind River's Workbench, but there have been run-time problems that I have, to date, not yet diagnosed.
Ron
Bruce Hill
Member Technical Staff
SLAC National Accelerator Lab
2575 Sand Hill Road M/S 10
Menlo Park, CA  94025
registerRecordDevice... crashes IOC during startup Benjamin Franksen
Re: registerRecordDevice... crashes IOC during startup Andrew Johnson
Re: registerRecordDevice... crashes IOC during startup Ron Sluiter
Prev: New version of STAR EPICS Virtual Machine (July 2013) Jiro Fujita
Next: Re: multiple servers on the same (loopback) interface Jameson Graef Rollins
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <2013>  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: registerRecordDevice... crashes IOC during startup Ron Sluiter
Next: Updating the RDB archiver at the STAR experiment L. C. De Silva
