1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <2013>  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <2013>  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: multiple servers on the same (loopback) interface
To: [email protected]
Date: Tue, 09 Jul 2013 18:06:41 -0700
On Tue, Jul 09 2013, Jameson Graef Rollins <[email protected]> wrote:
> Hey, folks.  I'm trying to run multiple IOCs on the same host and
> network interface and I'm looking for tips to help get it working
> cleanly.  I'm aware of some of the issues of servers sharing the same
> interface [0].  However, I assume there must be a way to support this
> situation, since I imagine it must be common.  But I'm having a lot of
> trouble getting it to work.
Someone offline has pointed me to an undocumented solution that seems to
work fine, and I wanted to share it here for others that may be
interested.
Apparently addresses specified in EPICS_CA_ADDR_LIST can include
colon-separated port specifiers, i.e. N.N.N.N:PORT.  This means one can
instantiate the servers on different ports:
EPICS_CAS_INTF_ADDR_LIST=localhost EPICS_CAS_SERVER_PORT=58900 ./test/testioc.py TEST0:
EPICS_CAS_INTF_ADDR_LIST=localhost EPICS_CAS_SERVER_PORT=58901 ./test/testioc.py TEST1:
and specify both to the client:
0$ EPICS_CA_ADDR_LIST='localhost:58900 localhost:58901' caget -t TEST0:FOO
0
0$ EPICS_CA_ADDR_LIST='localhost:58900 localhost:58901' caget -t TEST1:FOO
0
0$
The client therefore doesn't need to know which channels are at which
port.  This also works for localhost, so dummy network interfaces aren't
required.  This is a nice simple solution to the problem.
Unfortunately, it appears that this behavior (that ports can be
specified in the CA_ADDR_LIST list) is undocumented.  At least I can't
find reference to it in any of the CA documentation that I've found so
far.  If anyone sees a problem with this method please let me know.
Thanks so much for everyone's suggestions.
jamie.
Attachment: pgpeTBsndsuhs.pgp
Description: PGP signature
RE: multiple servers on the same (loopback) interface Hu, Yong
multiple servers on the same (loopback) interface Jameson Graef Rollins
Prev: Re: registerRecordDevice... crashes IOC during startup Bruce Hill
Next: Another strange CA observation Benjamin Franksen
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <2013>  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: RE: multiple servers on the same (loopback) interface Hill, Jeff
Next: RE: multiple servers on the same (loopback) interface Hu, Yong
