Hi Jamie,
In fact, "ports can be specified in the CA_ADDR_LIST list" is DOCUMENTED: http://www.aps.anl.gov/epics/base/R3-14/8-docs/CAref.html
All Channel Access (CA) configuration occurs through EPICS environment variables. When searching for an EPICS environment variable EPICS first looks in the environment using the ANSI C getenv() call. If no matching variable exists then the default specified in the EPICS build system configuration files is used.
Name Range Default
EPICS_CA_ADDR_LIST {N.N.N.N N.N.N.N:P ...} <none>
If a client needs to communicate with two servers that are residing at different port numbers then an extended syntax may be used with the EPICS_CA_ADDR_LIST environment variable. Each host name or IP address in the EPICS_CA_ADDR_LIST may be immediately followed by a colon and an IP port number without intervening whitespace. Entries that do not specify a port number will default to EPICS_CA_SERVER_PORT.
C shell setenv EPICS_CA_ADDR_LIST "1.2.3.255 8.9.10.255:10000"
N.N.N.N:P is the IP_address:port_number
Yong
-----Original Message-----
From: [email protected] [mailto:[email protected]] On Behalf Of Jameson Graef Rollins
Sent: Tuesday, July 09, 2013 9:07 PM
To: [email protected]
Subject: Re: multiple servers on the same (loopback) interface
On Tue, Jul 09 2013, Jameson Graef Rollins <[email protected]> wrote:
> Hey, folks. I'm trying to run multiple IOCs on the same host and
> network interface and I'm looking for tips to help get it working
> cleanly. I'm aware of some of the issues of servers sharing the same
> interface [0]. However, I assume there must be a way to support this
> situation, since I imagine it must be common. But I'm having a lot of
> trouble getting it to work.
Someone offline has pointed me to an undocumented solution that seems to work fine, and I wanted to share it here for others that may be interested.
Apparently addresses specified in EPICS_CA_ADDR_LIST can include colon-separated port specifiers, i.e. N.N.N.N:PORT. This means one can instantiate the servers on different ports:
EPICS_CAS_INTF_ADDR_LIST=localhost EPICS_CAS_SERVER_PORT=58900 ./test/testioc.py TEST0:
EPICS_CAS_INTF_ADDR_LIST=localhost EPICS_CAS_SERVER_PORT=58901 ./test/testioc.py TEST1:
and specify both to the client:
0$ EPICS_CA_ADDR_LIST='localhost:58900 localhost:58901' caget -t TEST0:FOO
0
0$ EPICS_CA_ADDR_LIST='localhost:58900 localhost:58901' caget -t TEST1:FOO
0
0$
The client therefore doesn't need to know which channels are at which port. This also works for localhost, so dummy network interfaces aren't required. This is a nice simple solution to the problem.
Unfortunately, it appears that this behavior (that ports can be specified in the CA_ADDR_LIST list) is undocumented. At least I can't find reference to it in any of the CA documentation that I've found so far. If anyone sees a problem with this method please let me know.
Thanks so much for everyone's suggestions.
jamie.
- RE: multiple servers on the same (loopback) interface Jameson Graef Rollins
- multiple servers on the same (loopback) interface Jameson Graef Rollins
- Re: multiple servers on the same (loopback) interface Jameson Graef Rollins
Re: Another strange CA observation Benjamin Franksen
<2013>
2025
2026
<2013>
2025
2026
