1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <20132014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <20132014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: RE: fsmRecord Initial State
To: "Costello, Charles C." <[email protected]>, "[email protected]" <[email protected]>
Cc: "Fujita, Jiro" <[email protected]>
Date: Wed, 24 Jul 2013 14:59:10 +0000
It's been a while, but I've worked with fsmRecord and have had no such problem.
IOW, the transitions worked as advertised, right out the box.
It's not clear to me whether
   field(TST0, "1")
is a valid transition or not.
It may be worth performing a "real" test for your TST0 condition, such as "pvX > 0."
Start your IOC with pvX = 0, then set it to 1.0 and see if your record transitions then.
Before trying any "real" work, though, make sure to check .STAT to see if you don't have a trivial problem with your record.
Cheers -Mathias
the stuff below works for me...
# Initial FSM State
# checks for auto/manual
record(fsm, "$(dipole):fsm:init") {
  field(INP, "@$(dipole):fsm;Init")
  field(SCAN, "2 second") # no hurry here
  field(VAL, "YES")
  field(TST0, "$(dipole):auto.VAL PP")
  field(TRN0, "$(dipole):fsm:matching PP")
  field(TST1, "$(dipole):auto.VAL PP")
  field(INV1, "1") #
  field(TRN1, "$(dipole):fsm:manual PP") # either auto is true or not...
  # nothing else to do
# manual state
record(fsm, "$(dipole):fsm:manual") {
  field(INP, "@$(dipole):fsm;Manual")
  field(SCAN, "5 second")
  field(TST0, "$(dipole):auto")
  field(TRN0, "$(dipole):fsm:matching PP") # transition to 'matching'
RE: fsmRecord Initial State Costello, Charles C.
Prev: Odd problems with RHEL6 diskless machines tom.cobb
Next: Re: Odd problems with RHEL6 diskless machines Andrew Johnson
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <20132014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: fsmRecord Initial State Costello, Charles C.
Next: RE: fsmRecord Initial State Costello, Charles C.
