1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <2013>  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <2013>  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: CA question with two identical servers
To: "Goff, Steven J" <[email protected]>
Date: Fri, 26 Jul 2013 15:44:19 -0600
On 7/26/2013 8:32 AM, Goff, Steven J wrote:
I would like to use one CA application or MEDM display that will connect
to two identical servers running the same PVs. I would like both servers
to receive the Channel Access ca_put at the same time. This might mean I
have to modify EPICS code for each server to receive the data
simultaneously.
Any ideas on how I would achieve this?
One question is why do you want to do this?
The redundant IOC software was originally used to run two IOCs each of which talks on the same bus (so only one controls hardware at a time). I modified the redundant IOC software, so it can be used to setup 2 IOCs that command redundant hardware. Info nodes can be used to choose which records are synced, so that command channels can be kept in sync, while readback channels respond to the state of the hardware. Joerg Penning at DESY maintains it, and he has my changes. In this case only one IOC (the master) will respond via channel access, but they communicate with each-other to stay in sync, and the slave will take over if the mast fails.
If you just want to send a put to two IOCs simultaneously, you could use different PV names on each IOC, and have a soft IOC with a third PV (that your CA application connects to) this record could cause a dfanout to send puts to both IOCs.
Scott Baily
AOT-IC, MS H820
Los Alamos National Laboratory
Los Alamos, NM 87545
ph: (505) 606-2260
CA question with two identical servers Goff, Steven J
Prev: RE: CA question with two identical servers Emmanuel Mayssat
Next: Re: CA question with two identical servers J. Lewis Muir
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <2013>  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
