Hi Igor,
With EPICS and asyn you typically create an asyn port driver that is connected to that TCP or serial port. That is a standard driver that comes with asyn.
You can then send messages to that port in several ways.
One way is to use StreamDevice to create the outgoing messages and parse the responses. StreamDevice provides device support for many types of EPICS records. You just need to write a protocol file that describes how to create outgoing messages and parse the responses.
You could also use standard asyn device support and write your own driver that has knowledge of your microcontroller, and then communicates to the device through the standard TCP or serial asyn driver. That is how many motor controller and areaDetector drivers work, for example.
It depends how complex your device is, and where you want to put the knowledge of the message content.
Sent: Tuesday, August 06, 2013 9:12 AM
To: Mark Rivers; [email protected]
Subject: RE: Record Parameters in Asyn Port Driver
Hi Mark,
I am developing an IOC to communicate with a micro-controller using TCP/IP and Serial communication. I need to send messages to this devices according to some parameters specified in the records.
For example:
If I had a record with this inp field:
field(INP, "@$(address).$(variableID=1).$(nbytes=4)")
I could use the following code in device support to get this values (not using asyn):
static long init_record_mbbo(mbboRecord *record){
int address,variable,numbytes;
if(sscanf(record->inp.value.instio.string, "%d.%d.%d", &address,&variable,&numbytes)!=3)
return S_db_errArg;
The meaning of these fields are:
Send a message to a device whose address is "address", read (or write) a variable whose id is 1, and whose size is 4 bytes.
And also, if I wanted to use the "number of bits" field in mbbi/mbbo records I could just simply use the code:
number_of_bits = record->nobt;
This is what I wanted my device and driver to do. Do I make myself clear about it?
Igor H. Soares Nunes
Centro Nacional de Pesquisa em Energia e Materiais (Cnpem)
Laboratório Nacional de Luz Síncrotron (Lnls)
Grupo de Diagnóstico de Feixes (Dig)
Sent: Monday, August 05, 2013 2:28 PM
To: Igor H. Soares Nunes; [email protected]
Hi Igor,
The idea of asyn port drivers is that they don't know anything about the EPICS records. They only know about the standard asyn interfaces (asynInt32, asynUInt32Digital, asynOctet, etc.). The device-independent device support in asyn/devEpics is the only code that knows about the record fields.
Can you please explain what you want your driver to do, and I can probably tell you how to do it without your asyn port driver needing to know anything about the record fields.
From: [email protected] [[email protected]] on behalf of Igor H. Soares Nunes [[email protected]]
Sent: Sunday, August 04, 2013 2:27 PM
To: [email protected]
Subject: Record Parameters in Asyn Port Driver
Hello everyone,
I'm developing an IOC using Asyn Port Driver, and I couldn't find out how to get some record parameters in the device support code (cpp file).
I need to get the INP and OUT parameters (port,addres,mask,timeout,...) and also NOBT for mbbi and mbbo records. As well as parameters for ai and ao records (EGUF, EGUL, etc).
Can anyone help me?
- Record Parameters in Asyn Port Driver Igor H. Soares Nunes
- RE: Record Parameters in Asyn Port Driver Mark Rivers
- RE: Record Parameters in Asyn Port Driver Igor H. Soares Nunes
Re: Modbus Zenon Szalata
<2013>
2025
2026
Wireshark CA plugin Eric Williams
<2013>
2025
2026
