1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <2013>  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <2013>  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: motorRecord simulation & STUP field
To: "Pearson, Matthew R." <[email protected]>
Date: Fri, 9 Aug 2013 14:05:49 +0000
> Martin is actually using the 'phase 2' simulation driver. The phase 3
> sim driver also has support for on-demand status updates.
Which simulation driver is recommended? Do they all have the same
behavior? Or is it wise to use the 'phase 2' simulation driver when
simulating a device that only has a 'phase 2' driver?
How can I find out to which phase a driver belongs?
> Looking at the code, I think it should work. I just tested it with
> both types of driver, and it works for me…
> Could you send me a dbpr of the motor record?
I repeated the test with your DB file and st.cmd. Unfortunately the
record is still stuck in BUSY state. See the attached file for details.
Martin
epics> dbpr mkp:Mot:Sim1 4
ACCL: 0.1           ACKS: INVALID       ACKT: YES           ADEL: 0.5
ALST: 0             ASG:                ASP: (nil)          ATHM: 1
BACC: 0.1           BDST: 0             BKPT: 00            BVEL: 0
CARD: -1            CBAK: 0x976160      CDIR: 0             CNEN: Disable
DCOF: 0             DESC: sim           DHLM: 50000000      DIFF: 0
DINP:CONSTANT       DIR: Pos            DISA: 0             DISP: 0
DISS: NO_ALARM      DISV: 1             DLLM: -50000000     DLY: 0
DMOV: 1             DOL:CONSTANT        DPVT: 0x976190      DRBV: 0
DSET: 0x7fbf8f8b2880                    DTYP: asynMotor     DVAL: 0
EGU: mm             ERES: 1.0e-03       EVNT: 0             FLNK:CONSTANT 0
FOF: 0              FOFF: Variable      FRAC: 1             HHSV: NO_ALARM
HIGH: 0             HIHI: 0             HLM: 50000000       HLS: 0
HLSV: MINOR         HOMF: 0             HOMR: 0             HOPR: 0
HSV: NO_ALARM       HVEL: 0             ICOF: 0             INIT:
JAR: 50             JOGF: 0             JOGR: 0             JVEL: 5
LCNT: 0             LDVL: 0             LLM: -50000000      LLS: 0
LLSV: NO_ALARM      LOCK: NO            LOLO: 0             LOPR: 0
LOW: 0              LRLV: 0             LRVL: 0             LSET: 0x976e60
LSPG: Go            LSV: NO_ALARM       LVAL: 0             LVIO: 0
MDEL: 0             MIP: 0              MISS: 0
MLIS: 80 69 02 38 bf 7f 00 00 80 69 02 38 bf 7f 00 00 01 00 00 00
MLOK: 60 5f 97 00 00 00 00 00           MLST: 0             MMAP: 0
MOVN: 0             MRES: 1.0e-03       MSTA: 10            NAME: mkp:Mot:Sim1
NMAP: 0             NSEV: NO_ALARM      NSTA: NO_ALARM      NTM: YES
NTMF: 2             OFF: 0              OMSL: supervisory
OUT:INST_IO @asyn(sim1,1)               PACT: 0             PCOF: 0
PHAS: 0             PINI: NO            POST:               PP: 0
PPN: (nil)          PPNR: (nil)         PREC: 3             PREM:
PRIO: LOW           PROC: 0             PUTF: 0             RBV: 0
RCNT: 0             RDBD: 1.0e-03       RDBL:CONSTANT       RDES: 0x955cb0
RDIF: 0             REP: 0              RHLS: 0             RINP:CONSTANT
RLLS: 0             RLNK:CONSTANT       RLV: 0              RMOD: Default
RMP: 0              RPRO: 0             RRBV: 0             RRES: 0
RSET: 0x7fbf8f8b2440                    RTRY: 0             RVAL: 0
RVEL: 0             S: 25               SBAK: 0             SBAS: 0
SCAN: Passive       SDIS:CA_LINK mkp:Mot:Sim1:SDIS.VAL NPP NMS
SET: Use            SEVR: INVALID       SMAX: 25            SPMG: Go
SPVT: (nil)         SREV: 200           SSET: 0             STAT: LINK
STOO:CONSTANT       STOP: 0             STUP: OFF           SUSE: 0
SYNC: 0             TDIR: 0             TIME: 2013-08-09 09:48:19.865234929
TPRO: 0             TSE: 0              TSEL:CONSTANT       TWF: 0
TWR: 0              TWV: 1              UDF: 0              UEIP: No
UREV: 0.2           URIP: No            VAL: 0              VBAS: 0
VELO: 5             VERS: 6.7           VMAX: 5             VOF: 0
epics> dbpf mkp:Mot:Sim1.STUP 1
DBR_STRING:          "BUSY"
STOO:CONSTANT       STOP: 0             STUP: BUSY          SUSE: 0
SYNC: 0             TDIR: 0             TIME: 2013-08-09 09:48:49.109445369
Re: motorRecord simulation & STUP field Pearson, Matthew R.
motorRecord simulation & STUP field Konrad, Martin
Re: motorRecord simulation & STUP field Ron Sluiter
Prev: Re: [asyn] link already open! Pavel Maslov
Next: Re: motorRecord simulation & STUP field Konrad, Martin
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <2013>  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: motorRecord simulation & STUP field Pearson, Matthew R.
Next: Re: motorRecord simulation & STUP field Pearson, Matthew R.
