1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <20132014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <20132014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: AW: [asyn] link already open!
To: Pavel Maslov <[email protected]>
Date: Tue, 13 Aug 2013 11:42:52 -0500
Hi Pavel,
On 08/13/2013 10:20 AM, Pavel Maslov wrote:
Do you mean, although I am building my support module with base.dbd
included, I may provide my own  *_registerRecordDeviceDriver.cpp file
(corrected one - comment out everything  related to base.dbd) and get
away with it?
I believe so, but that does add a maintenance burden that you need to be aware of whenever you upgrade. New versions of EPICS Base are very likely to require that you recreate that .cpp file again from scratch (because the C++ code generated by the registerRecordDeviceDriver.pl script can change without notice), and new versions of external modules such as Asyn will probably change the DBD file and thus need updates.
I would strongly recommend that you document what you're doing very clearly for your successors or your future self, and maybe explain exactly how to switch back to using standard EPICS builds too.
- Andrew
Advertising may be described as the science of arresting the human
intelligence long enough to get money from it. -- Stephen Leacock
Re: AW: [asyn] link already open! Andrew Johnson
[asyn] link already open! Pavel Maslov
RE: [asyn] link already open! Mark Rivers
Re: [asyn] link already open! Pavel Maslov
Re: [asyn] link already open! Dirk Zimoch
AW: [asyn] link already open! Zimoch Dirk
Re: AW: [asyn] link already open! Pavel Maslov
Prev: Re: AW: [asyn] link already open! Pavel Maslov
Next: Accessing Raspberry Pi GPIO through EPICS Peter Linardakis
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <20132014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Next: Re: AW: [asyn] link already open! Andrew Johnson
