1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <2013>  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <2013>  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: High density thermal diode monitoring
To: <[email protected]>
Date: Wed, 14 Aug 2013 17:18:48 -0500
Is your diode something like this?
http://www.omega.com/pptst/CY670.html
If you can measure in the 2-wire mode, one of the Arduino boards might just satisfy your requirements. The Arduino mega2560 has 16 ADC channels at 10-bit and can communicate readings out the USB connection without any added hardware shields. We have developed just recently a simple command/response protocol and Stream support example that seems a good training example for Stream protocol files.
~$60 http://www.amazon.com/SmartProjects-Mega-Arduino-MEGA-Board/dp/B004A7H3DG
~$30  http://www.amazon.com/OSEPP-Mega-2560-Arduino-Compatible/dp/B005SUXZT0
Requires: EPICS + asyn + USB port + our epicsduino code + linux IOC
Pete
On 8/14/2013 4:39 PM, Arnold, Ned D. wrote:
Hello all -
Has anyone implemented a cost effective solution for monitoring large
quantities (~96) of thermal diodes for cryogenic temperature monitoring
(down to 2K)?  The solution proposed here is either the Lakeshore Model
218 or Model 224, both of which are ~$250/channel ... I was hoping to
find something cheaper.
Any proven alternatives?
Thanks -
    Ned
PS: I searched tech-talk and only found solutions for RTDs or
thermocouples ...
Pete R. Jemian, Ph.D.                <[email protected]>
Beam line Controls and Data Acquisition, Group Leader
Advanced Photon Source,   Argonne National Laboratory
Argonne, IL  60439                   630 - 252 - 3189
   Education is the one thing for which people
      are willing to pay yet not receive.
High density thermal diode monitoring Arnold, Ned D.
Prev: High density thermal diode monitoring Arnold, Ned D.
Next: Re: Accessing Raspberry Pi GPIO through EPICS Peter Linardakis
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <2013>  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Next: Re: High density thermal diode monitoring Steven Hartman
