1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <20132014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <20132014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: putNotify db links
To: Dirk Zimoch <[email protected]>
Cc: EPICS <[email protected]>
Date: Thu, 15 Aug 2013 11:29:02 -0400
The sseq record supports put_notify:
http://www.aps.anl.gov/bcda/synApps/std/sseqRecord.html
I've used this in the past to replace seq record instances.
Cheers,
Matt
On Aug 15, 2013, at 11:18 AM, Dirk Zimoch <[email protected]> wrote:
> Hello all,
> Is it possible to make a database link wait for completion?
> If not, is this worth to be considered for a future EPICS version?
> Example:
> A seq record S triggers two records, A and B. A has an asynchronous
> device support (or is the beginning of a processing chain that contains
> an asynchronous device support).
> record (seq, "S")
>    field (LNK1, "A.PROC PP")
>    field (LNK2, "B.PROC PP")
> record (ai, "A")
>    field (DTYP, "async dev sup")
>    field (INP,  "...")
> record (ao, "B")
>    field (OMSL, "closed_loop")
>    field (DOL,  "A")
>    field (OUT,  "...")
> When I do a caput with callback to S, the call only returns after A and
> B have both processed, as expected.
> caput -w 10 -c S 1
> However, B starts processing before A has finished. That is because A is
> asynchronous. Thus A has only just started processing when B is
> triggered. This is bad if B (or something down its processing chain)
> depends on A because B gets an old value.
> Now it would be nice to have "put notify" links, e.g:
>    field (LNK1, "A.PROC PN")
> So that LNK2 is only processed when the whole LNK1 chain has finished
> processing.
> The same syntax and mechanism may be useful for input links too in order
> to avoid getting old values from asynchronous device supports.
> Any comments?
> Does something like this already exists or is it already planned?
> I think with dbPutNotify the necessary infrastructure is already there.
> Dirk
putNotify db links Dirk Zimoch
Prev: putNotify db links Dirk Zimoch
Next: Re: putNotify db links Andrew Johnson
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <20132014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
