Hi Dirk,
On 08/15/2013 10:18 AM, Dirk Zimoch wrote:
Is it possible to make a database link wait for completion?
Not a regular link, but the "Async Soft Channel" output device supports
that come with Base 3.14 do exactly that. In 3.15 we also provide input
device supports which do process-get as well, which Marty had to do some
major internal surgery to support. The facility is now called
process-notify instead of put-notify as a result.
Now it would be nice to have "put notify" links, e.g:
field (LNK1, "A.PROC PN")
So that LNK2 is only processed when the whole LNK1 chain has finished
processing.
Unfortunately we can't do this for regular links because the API that
record types call to do put and get operations on regular links doesn't
provide for the necessary callback-on-completion which would allow for
asynchronous operations like that. Making this something that could be
configured on a per-link basis would require rewriting every record type
to support such links.
- Andrew
Advertising may be described as the science of arresting the human
intelligence long enough to get money from it. -- Stephen Leacock
- putNotify db links Dirk Zimoch
Re: putNotify db links Pearson, Matthew R.
RE: High density thermal diode monitoring Mooney, Tim M.
<2013>
2025
2026
DeltaTau Clipper, DeltaTau & EtherCAT, Beckhoff PV
<2013>
2025
2026
