1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <20132014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <20132014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: RE: High density thermal diode monitoring
To: "Arnold, Ned D." <[email protected]>, "[email protected]" <[email protected]>
Date: Thu, 15 Aug 2013 17:03:51 +0000
Maybe you could make a multiplexer.  Here's something I ran across that talks about the problems of switching low voltage signals with nonmagical relays:
Tim Mooney
From: [email protected] [[email protected]] on behalf of Arnold, Ned D. [[email protected]]
Sent: Wednesday, August 14, 2013 4:39 PM
To: [email protected]
Subject: High density thermal diode monitoring
Hello all -
Has anyone implemented a cost effective solution for monitoring large quantities (~96) of thermal diodes for cryogenic temperature monitoring (down to 2K)?  The solution proposed here is either the Lakeshore Model 218 or Model 224, both of which are ~$250/channel ... I was hoping to find something cheaper.
Any proven alternatives?
Thanks -
   Ned
PS: I searched tech-talk and only found solutions for RTDs or thermocouples ...
High density thermal diode monitoring Arnold, Ned D.
Prev: Re: putNotify db links Andrew Johnson
Next: DeltaTau Clipper, DeltaTau & EtherCAT, Beckhoff PV
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <20132014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: RE: High density thermal diode monitoring Dalesio, Leo
Next: Displaying Linux PID's or pthread opaque pthread_t? nick.rees
