1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <20132014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <20132014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Using MEDM for timing
To: [email protected]
Date: Tue, 20 Aug 2013 20:20:06 +0530
Hi All,
I need to use MEDM application for building a programmable temperature controller. That is the system should be able to heat some fluid at some pre determined temperature for a period and increase the temperature to a higher value and keep it for some period.
I could not find any widget that i can use for this application. It is appreciated if you could give me some guidance on the above.
Thanks & Regards,
Nalaka
RE: Using MEDM for timing Mark Rivers
Prev: RE: Channel Acess Dalesio, Leo
Next: Re: Channel Acess Andrew Johnson
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <20132014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: Channel Acess Andrew Johnson
Next: RE: Using MEDM for timing Mark Rivers
