1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <20132014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <20132014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: RE: Using MEDM for timing
To: "'nalaka samarasinghe'" <[email protected]>, "[email protected]" <[email protected]>
Date: Tue, 20 Aug 2013 15:17:00 +0000
I think you are asking the wrong question.  You don’t need a special medm widget for that, the standard widgets can be used.
You do probably need 2 things:
1) A feedback record.  The EPICS epid record can be used for this.  It can read the temperature from your readout device and control the power to a power supply using a D/A converter, for example.
2) Some other record or client to control the setpoint of the feedback record.  You could use the sscan record in table mode to generate an arbitrary temperature profile, for example. Or you could use a client like Python, IDL, etc.
I have attached a screen shot of one of our temperature control screens.  At the time I took this screen shot the thermocouple was broken, so the temperature reading is meaningless, but you get the idea.
From: [email protected] [mailto:[email protected]] On Behalf Of nalaka samarasinghe
Sent: Tuesday, August 20, 2013 9:50 AM
To: [email protected]
Subject: Using MEDM for timing
Hi All,
I need to use MEDM application for building a programmable temperature controller. That is the system should be able to heat some fluid at some pre determined temperature for a period and increase the temperature to a higher value and keep it for some period.
I could not find any widget that i can use for this application. It is appreciated if you could give me some guidance on the above.
Thanks & Regards,
Nalaka
Attachment: 1000_Ton_LVP_furnace.png
Description: 1000_Ton_LVP_furnace.png
Re: Using MEDM for timing Pete Jemian
Using MEDM for timing nalaka samarasinghe
Prev: Re: Channel Acess Andrew Johnson
Next: Re: Channel Acess Kevin Peterson
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <20132014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Using MEDM for timing nalaka samarasinghe
Next: Re: Using MEDM for timing Pete Jemian
