1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <2013>  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <2013>  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: streamdevice to find the last match
To: [email protected]
Date: Fri, 23 Aug 2013 16:20:24 +0200
On 23.08.2013 16:11, Dirk Zimoch wrote:
Dehong,
I am not sure if the payload data is the first number or the P= number
or both.
In any case with a %*/.*BOS*/ you should be able to find the last BOS in
your input. After that start reading your data. If P= is your data it
would look like this:
in "%*/.*BOS/*d,P=%dEOS\r\n";
Typo.
in "%*/.*BOS/%*d,P=%dEOS\r\n";
BTW: ExtraInput = Ignore is almost always a bad idea. Use it only if
absolutely necessary.
Dirk
On 23.08.2013 09:55, Dirk Zimoch wrote:
Hello Dehong,
Is your record "I/O Intr"? I assume so because your STATUS protocol does
not have any out command.
In that case and if you set InTerminator = CR LF, you should actually
get 2 messages and the record should be processed twice. Thus at the
end, your record will have the correct value.
Skipping intermediate results is tricky on the protocol level, because
how should StreamDevice know that no more input is about to come? What
if the gap between the messages is sometimes so big, that you actually
get 2 messages?
But In case you really always get a double message as below and want to
read the second value only you can skip the first one:
in "BOS%*d,P=%*dEOS\r\nBOS%d,P=%(otherrecord)dEOS\r\n"
In case you may have an arbitrary number of messages connected and
always want to skip all but the last, things become tricky. I have to
make up a PCRE. The idea is to do a greedy search for everything up to
"BOS" and then read the data. I will send you the PCRE later.
Dirk
On 22.08.2013 21:17, Zhang, Dehong wrote:
Hi Dirk and Friends,
(Sorry if you get this 2 times. I had a wrong address with my previous
send)
I run into 2 little problems: I wait for the hardware to send a
message like
"BOS123456,P=987654EOS\r\n".
Here BOS is my starting label and EOS the ending label.
Due to timing, which I cannot control, sometimes I would receive 2
messages
together, like:
"BOS123456,P=987654EOS\r\nBOS345,P=987649EOS\r\n".
Here the first one was sent when the state was still changing, the
second one
was sent when the state stablizes. But the time in between is so short
that the
2 messages just come out as one. How can I skip the first match, only
get the
second/last match?
My protocal is like:
InTerminator = CR;
OutTerminator = CR LF;
ReplyTimeout = 800;
ReadTimeout = 100;
WriteTimeout = 100;
ExtraInput = Ignore;
# Reports from the controller
STATUS { ReplyTimeout = 50; ReadTimeout = 10; InTerminator =; in
"%.1/BOS([0-9,P=]*EOS)/"; }
I tried to use the "$" anchor, but cannot get it to work -- maybe
because "$" is a special
character in streamdevice.
Related to this, sometimes the time in between is not so short that
the 2 messages
do come out separately, but the time in between is short enough so
that my stringin
record misses the second message. How can I avoid this? Tune the
ReplyTimeout,
ReadTimeout and InTerminator?
Thank you for your advice. Best regards,
Dehong
streamdevice to find the last match Zhang, Dehong
Re: streamdevice to find the last match Dirk Zimoch
Prev: Re: streamdevice to find the last match Dirk Zimoch
Next: RE: Asyn AutoConnect and stream device on a soft IOC Mark Rivers
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <2013>  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Next: RE: streamdevice to find the last match Zhang, Dehong
