1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <20132014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <20132014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Segmentation fault et_wish
To: [email protected]
Date: Sun, 25 Aug 2013 12:33:31 +0530
Hi All,
I am using et_wish for control system implementation and I wrote a small application to display temperature reading on a label widget. It displays the temperature but does not get updated realtime.
I have copied the tcl tk program below. Please help me to diagnose the problem with the below code.
Many thanks,
Nalaka
Code :
wm geometry . 360x150+200+100
pv linkw temp temp_val1
pv umon temp change
label .l1 -font {Helvetica 16}  -text " $temp"
#button .btnchange -text change -command {change} -font { -size 15}
grid .l1 -row 0  -column 0
#grid .btnchange -row 1 -column 0
#label .l1 -font {Helvetica 16} -width 10 -textvariable temp
proc change {} {
 global temp
.l1 configure -text "$temp"
Re: Segmentation fault et_wish Dirk Zimoch
Prev: Re: using et_wish for temperature monitoring Pete Jemian
Next: Re: Segmentation fault et_wish Dirk Zimoch
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <20132014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
